Hello.
Posted: Tue Feb 25, 2025 3:14 pm
Had a few questions relating to XT and XT2 on Facebook. I was guided here by jfheath for usefull dialogue, so here I am, be gentle.
Dedicated forums for Garmin Zumo motorcycle satellite navigation. All questions answered from problems, route planning, touring to tips and tricks
https://www.zumouserforums.co.uk/
Welcome to the forum. It is made up of a bunch of folks who are courteous, kind, helpful, and above all, knowledgeable.madforthetar wrote: Tue Feb 25, 2025 3:14 pm Had a few questions relating to XT and XT2 on Facebook. I was guided here by jfheath for usefull dialogue, so here I am, be gentle.![]()
Ah yes - I went looking for the post - but according to the Facebook logs, I had a post and all associated replies deleted from the XT and XT2 owners group on FB - two days ago. No comment, no warning, no reason. Just deleted. I can't remember what I said, but somebody didn't like it. I know there was a link to this site. I probably hinted that the replies that you were getting were not very helpful !madforthetar wrote: Tue Feb 25, 2025 6:02 pm 1.I was pondering the difference between the XT and the XT2 where the Tread App and Explore cause deviations in poorly planned Routes/Tracks. I have read your posts on this subject and have stopped the synching so far so good.
Your BMW. The Zumos can be powered from their USB socket - but it is not a good idea. Was this your intention ? The problem is that the wire flaps around int he wind and it rattels the USB socket int he Zumo. That is only held in place by a soldered connection to the very fine metal coating on the circuit board - and a weak plastic clamp (if it is built the same as the 590). Over time the connections to the circuit board break. You either need to stop the cable moving in relation to the XT2 or get yourself a new cradle.madforthetar wrote: Tue Feb 25, 2025 6:02 pm 2.I am also looking to install the XT2 on my 2021 BMW R1250 GS Adventure having removed the OEM Nav Prep. I may put a BMW repair plug on and use the vacant Plug/Socket left by the said OEM Nav Prep. I also have the Lone Rider Motocan route to use if needs arise, along with fusing the cable and wiring it straight to the baattery.
I've not come across the BMW repair plug. I wired my XT in to the original loom using a £20 lead from Nippy Norman. It looks like that's been replaced by the cheaper Part No: MKS-ELA13585.madforthetar wrote: Tue Feb 25, 2025 6:02 pm
Same plug........Oem Bmw Motorcycle Repair Plug 3-Pin Original 611656 83300413585. Three yellow wires only 1 and 3 are required as 2 is a data cable I am told.colirv wrote: Wed Feb 26, 2025 10:32 amI've not come across the BMW repair plug. I wired my XT in to the original loom using a £20 lead from Nippy Norman. It looks like that's been replaced by the cheaper Part No: MKS-ELA13585.madforthetar wrote: Tue Feb 25, 2025 6:02 pm
