Which, of course, you're planning on sharing!
No satellite reception in new house.
- Has liked: 57 times
- Been liked: 53 times
- Has liked: 64 times
- Been liked: 167 times
Re: No satellite reception in new house.
- Has liked: 121 times
- Been liked: 85 times
From the on-line manual:
https://www8.garmin.com/manuals/webhelp ... D6D88.html
- Has liked: 131 times
- Been liked: 376 times
Here you go. I'm sure it's not original though. I apologize for not crediting the original source.
Setting a Simulated Location
If you are indoors or not receiving satellite signals, you can use
the GPS simulator to plan routes from a simulated location.
1 Select Settings > Navigation > GPS Simulator.
2 From the main menu, select View Map.
3 Tap the map twice to select an area. This zooms in the map.
4 Long press on the spot where you want to set the vehicle location.
The address of the location appears at the bottom of the screen.
5 Tap the location description.
6 Scroll down on the left of the resulting screen until you can tap on "Set Location".
