Page 1 of 4
Garmin Express 7.24.0 has been released
Posted: Sat Nov 09, 2024 7:31 pm
by Peobody
Garmin Express 7.24.0 has been released.
Release notes:
  • Removed toast notifications indicating an update is available for legacy PND devices.
  • Fixed an issue with users getting a server error when attempting to register TruSwing devices.
  • Fixed an issue with not offering an install or reinstall option for TOPO Active maps.
  • Fixed an issue with displaying incorrect mapping when a user is wanting to remove a map.
  • Fixed an issue when a user attempts to install a map but would get taken back to the device dashboard.
  • Fixed an issue with the Removable Storage option not appearing on the Manage Maps screen.
  • Other minor bug fixes and improvements.
Re: Garmin Express 7.24.0 has been released
Posted: Sat Nov 09, 2024 7:45 pm
by Peobody
I have installed and done an initial test of GE 7.24.0. This is what I check during my initial test:
- Does it recognize my XT? Yes
- Did the launch at startup option get enabled? No
- Did the keep running in background option get enabled? No
- Does the option to install maps to computer exist? Yes
Posted: Sat Nov 09, 2024 9:08 pm
by Peobody
Just a 'heads up' to let you know that when I started my XT following the GE check and disconnection from the PC, it did the 'do you want to import' prompt even though I had not transferred any new routes. I answered in the affirmative out of curiosity. It was the route in temp.gpx. That route had been imported, ridden, and deleted many weeks ago. The mechanism that keeps track of routes already imported from temp.gpx must have failed. I was not able to duplicate it so this is just an FYI.
Posted: Thu Nov 14, 2024 4:03 pm
by turbo19
Peobody wrote: Sat Nov 09, 2024 7:45 pm I have installed and done an initial test of GE 7.24.0. This is what I check during my initial test:
In my case, with a XT2...
- Does the option to install maps to computer exist? NO
I don´t know why, but I can only reinstall the maps in the XT2, but not in the PC :(
Posted: Fri Nov 15, 2024 7:22 pm
by twowheelstom
turbo19 wrote: Thu Nov 14, 2024 4:03 pm
to check what my XT does in Garmin Express, I noticed that under Map Updates Available, when I click on Map Details, the map details screen shows Options, when I click on Options, that's where I see Install Map to Computer. 8-)
Posted: Fri Nov 15, 2024 7:42 pm
by turbo19
twowheelstom wrote: Fri Nov 15, 2024 7:22 pm
Normally the option is there, but in the case of the XT2 and the Express version 7.24.0.0 that option does not appear to install on the computer.
Thanks ;) ,
Posted: Wed Nov 20, 2024 11:31 pm
by twowheelstom
I remember Express showing 3 options on installing new maps, 1. to computer only, 2. to device only, 3. to both computer and device.
are these options still available on the current version of Express 7.24.0 ?
Posted: Thu Nov 21, 2024 8:09 am
by turbo19
With this new version I can only reinstall the maps in the XT2. There are no the other options :(
Posted: Thu Nov 21, 2024 12:37 pm
by lkraus
Installation to Zumo XT and installation to PC are separate steps in Express 7.24.0.
Map Details -> CNNA Options :
Posted: Fri Nov 29, 2024 10:48 pm
by pdrt
turbo19 wrote: Thu Nov 21, 2024 8:09 am With this new version I can only reinstall the maps in the XT2. There are no the other options :(
I have the same problem: Map Details, Options only shows "Reinstall Map".
Garmin Zumo XT2, Software Version 4.80, Map Europa 2025.20
Garmin Express Version 4.24.0.0
Windows 10 Pro
