When making a route with Tread it syncs to the zumo but it’s not exactly the same. Why is that? The Zumo version has much less turns.
Sync with Tread
Sync with Tread
Reason: Typos in title - corrected so search will find it
Re: Sync with Tread
Welcome to the forum !
This is a route and not a track. You have just two points on the route. When the Zumo receives the route it often recalculates it. I noticed the other day that it mentioned that the XT2 didn't recognise the profile name used, and it had to recalculate. I hadn't set a name - I just used that set in tread. I think it was 'Zumo Motorcycle'.
I've yet to reproduce this and report it.
