This morning I posted 2 sequences of info about how to create CustomPOIs and How to use POIs in making a 'TourGuide'.
I remember playing around with these when I got my first Zumo a 550 in 2010 I think. The instructions from Garmin - which are not very clear - have remained the same since. I'd be surprised if they have changed them.
viewtopic.php?t=2826
and
viewtopic.php?t=2827
How to display custom POIs on the map
- Has liked: 427 times
- Been liked: 934 times
Re: How to display custom POIs on the map
My fault, you are right. With the GPS position simulated all the POIs appear. What have confused me is that the official garmin POI are visible even when you open the map to add a destination. Custom POI appear only during the navigation.jfheath wrote: ↑11 May 2024 22:33 This morning I posted 2 sequences of info about how to create CustomPOIs and How to use POIs in making a 'TourGuide'.
and
Anyway thanks for the info
I am still not sure about the last sentence. Generally when using the map in hand, POIs do not appear - immediately, but their visibility seems to depend on map scale, proximity and a time delay - like other map components, they seem to be drawn in layers. But I have noted certain map views when they do not appear.
Yesterday I was out for a ride and had forgotten all about my testing of POIs and had left them on the XT. i happened to be in the road that I had used and it cam as quite a surprise to hear my own voice in my ears saying 'Point One'. The photo popped up on the screen, and the map showed all the icons as they came within range. I wasn't navigating a route at the time - I just had a track drawn, and these were tour guide POIs. I had noted previously in simulation that the alert repeated while I was in the proximity circle. That didn't happen when actually riding. I'll go out and test POIs in case the non alerting of points not on the route is something that happens only in simulation.
