64gb sd card formatting
- Has liked: 45 times
- Been liked: 32 times
Re: 64gb sd card formatting
ok let me see if i have this right, if I format the 64gb card to FAT32, and it's in the zumo when doing new Garmin Map updates, and Express wants to put the new map file on this 64gb card, and there's already previous older garmin map files from before that still remain on the card, and being the 64 card has lots of FAT32 room on it, does this mean I can keep as many older garmin maps files on the 64 as i want without removing them? if yes then i assume it means that I would probably never have to manually go into the sd card to remove any older map files to make room for new ones. correct?
- Has liked: 64 times
- Been liked: 167 times
Express removes old maps while installing new ones. I've never seen it offer the option to keep old maps on the GPS. This is possibly to prevent having two routable maps active for the same area, which causes various errors, including lack of verbal directions, no displayed distance to next turn, etc.
I've never found a need to keep old maps. It's unlikely the old roads will suddenly reappear.
Updating maps really is not complex or difficult, just try it. With 16gb of internal memory, the 396 probably does not require a SD card for all of North America maps. I don't see any mention in other 396 threads about needing more space. If you then find you need or want more storage for music, reformat your card and put it in.
No. On the GPS the map files have specific file names, and the update will replace one map with the new one. The map files on your computer have the map version as part of the names so you can keep more than one map version on your computer. This is for Garmin maps. No idea what third party maps, like OSM do with their files.twowheelstom wrote: ↑02 Jan 2024 12:52 ok let me see if i have this right, "…………..it, does this mean I can keep as many older garmin maps files on the 64 as i want without removing them?
Michael S.
Trinity, North Carolina
It isn't as simple as that. If you use Express to install an update to your device and then leave the files of that update alone Express will replace them when it next does an update. If however for whatever reason you rename them or move them then Express won't touch them.
