Yes, the XT will show the "next street" even if you have no route active. And it should do this during an active route as well. In my case, while riding and following the track it will show the next street, but it's "stuck" on a street passed somewhere at the beginning of the ride. If I close the track and start it up again it will update itself and indicate the correct next street, until I start riding and then it doesn't change any more.jfheath wrote: ↑19 Nov 2023 05:42
So the question is, does the XT normally show things that are coming up ahead when you have no route active ?
I thought that I had seen this, but I am not sure. Does it show the road name or the speed limits for the road that you are on ?
I have a feeling that this information is stored as part if the route. But again, I have not been observant enough.
It may show speed camera locations as these are proximity alerts like POIs. You can plot points that have a 'perimeter fence' around them. as soon as you pass through the fence, you get an alert, or an mp3 recording is played. They work whether or not a route is loaded.
In contrast, the "street your driving on" listing at the bottom of the XT screen, has always worked fine.
Yes, I get speed limit signs while using my tracks.
I have never use POI alerts as you describe so I can't comment on that.
