Screwdriver size
Bear
Been liked: 3 times
Screwdriver size
Post by Bear »
Does anyone know what size Torx bit I need to take a Garmin apart please? I don't want to order a set starting at T5 only to find I need a T3.
ZFtracker
Has liked: 16 times
Been liked: 31 times
Re: Screwdriver size
Post by ZFtracker »
My Zumo 590 case requires a Torx T5 to remove the outer case.
Zumo 590
Montana 610
Drive 60
inReach Mini
Bear
Been liked: 3 times
Post by Bear »
Thank you. I'll buy something suitable in advance of the new battery for my nuvi, which seems to take the same screwdriver as the 595.
ZFtracker
Has liked: 16 times
Post by ZFtracker »
I got a nice small Torx screwdriver set off Amazon for $10-15 USD; covered T2 - T10 plus T15.
YMMV
Zumo 590
Montana 610
Drive 60
inReach Mini
Bear
Been liked: 3 times
Post by Bear »
I bought these https://www.toolstation.com/minotaur-to ... set/p67302 and the T5 was a perfect fit. For UK buyers it's worth searching for discount codes although they aren't badly expensive. Watch out when opening the Nuvi as some of them have more than one cable connecting the main pcb to the front panel and they do jump out (DAMHIC) and are fiddly to replace.
