I installed it, I couldn't figure out how to use it to solve my issue. It didn't seem to have any option to aquire latest map data
Cannot Update Zumo 660 Beyond 2015.20
Re: Cannot Update Zumo 660 Beyond 2015.20
This is starting to sound like the most likely explanation. What are the options in this case? Saw a YouTube with instructions for installing OpenStreetMap data, anyone found that to be a useful alternative?sussamb wrote: ↑03 Jul 2023 08:01Then perhaps you don't have lifetime maps, many early Garmin devices didn't. A call to Garmin should confirm that either way.Dad'sITadvisor wrote: ↑02 Jul 2023 23:46This was the first time thing I tried. Took over an hour to do the update but it just installed the exact same version that was already on there. Still the only option is 2015.20
It's not as good for on road navigation as the Garmin maps. However I would contact Garmin to check first. If indeed the unit doesn't have lifetime maps you can normally purchase a lifetime subscription
- Has liked: 105 times
- Been liked: 229 times
The last Lifetime Maps I purchased came from ebay for less than 1/2 of what Garmin wanted. Worked perfectly for at least 10 yrs until I quit updating the nuvi I had.
Seems like Garmin have stopped providing map updates for many older devices
https://support.garmin.com/en-US/?faq=F ... JG5A1p9tW5
In my recent thread on this, I was told that this message had been in their website for a long time.
viewtopic.php?t=2572
So I wonder if I connected up my 665 that won't update to a computer that has latest maps, would map install work to update maps? If only I knew someone near Baltimore, MD with latest msps that I could try this.
