How would you emphasize a mandatory fuel stop?
Has liked: 131 times
Been liked: 376 times
While working on creating the routes for an upcoming trip I noticed that there is a stretch of 120 miles without fuel. My co-riders normally don't plan their fuel stops but I want to include one with emphasis before that stretch especially since we will have ridden 130 miles before hitting that stretch. What technique would you use to create emphasis? Satnavs will be an XT, a Nav VI, and a Montana.
colirv
Has liked: 57 times
Been liked: 53 times
Re: How would you emphasize a mandatory fuel stop?
Post by colirv »
Won't an announced waypoint be sufficient? Perhaps you could drag the route onto the forecourt if that's shown on the map.
Colin
BMW R1250RS
https://www.namrider.com
colirv wrote: 29 Jun 2023 18:46 Won't an announced waypoint be sufficient?
One consideration is that none of us ride with spoken navigation enabled. A bigger concern is that we won't be low of fuel at the time we reach that waypoint. My riding buddies don't think that there as any reason to plan fuel stops so I want to minimize the chance of anyone riding by thinking they'll get fuel when they get low. I am thinking of naming the waypoint "Last fuel for 120 miles". I'm going to run a simulation and see what that looks like.
Edit: Simulation run. That name is displayed clearly enough on my XT to serve the purpose.
Has liked: 106 times
Been liked: 232 times
Peobody wrote: 29 Jun 2023 19:27
I think I'd also point it out to everyone prior to leaving out for the day and again at each stop like, "now, don't forget...."
rbentnail wrote: 29 Jun 2023 20:41
I think I'd also point it out to everyone prior to leaving out for the day and again at the stop prior like, "now, don't forget...."
rbentnail wrote: 29 Jun 2023 20:41 I think I'd also point it out to everyone prior to leaving out for the day and again at each stop like, "now, don't forget...."
I'll need the reminder. The trip isn't until the end of July and this particular issue is on day three.
Has liked: 389 times
Been liked: 848 times
If you :
Create a Waypoint a mile ahead. I mean a proper WAYPOINT created with the BC flag tool, which then gets transferred to The XT 'Favourite' or 'Saved' locations, and call it "Fuel Alert". and another at the filling station called "Last Fuel for 120 miles"
Make both points a Via Point. Announcing.
The message banner, and the spoken message will both say:
Approaching Fuel Alert
Arriving at Fuel Alert on the left
and then
Approaching Last Fuel for 120 Miles
Arriving at Last Fuel for 120 Miles on the right.
The use of the words left and right seems random to me if the point is placed on the route.
The points MUST be created as Waypoints, as the XT and maybe the 595 will probably change the name given to any other sort of route point. This may mean that you have to use BaseCamp to create the route as very few other routing programs use genuine Garmin Waypoints.
MRA and many other routing programs use the word 'Waypoint' but non of their routes actually create a saved Garmin Waypoint - so the name is likely to change.
I had observed at one time that MRA route points did not have their name changed, and concluded that this had something to do with the Subclass entry in the MRA gpx file. But i never proved it conclusively for all situations, and the fact that it doesn't create Waypoints that get transferred to favourites leaves me with some doubt about that.
I dont know how a Montana treats Via Points.
The other alternative is to give them two routes, the first one ending at the filling station. The second one starting at the exit from the filling station. Meet up before the exit and remind them to load the next route, and which destination to select.
Has liked: 107 times
Been liked: 151 times
jfheath wrote: 01 Jul 2023 06:06 I had observed at one time that MRA route points did not have their name changed, and concluded that this had something to do with the Subclass entry in the MRA gpx file. But i never proved it conclusively for all situations....
I can confirm that that has to do with the <subclass> . Via and Shaping points that have either no <subclasses> or the special value '0000000ffffff' don't get renamed.
