I'm a tad late with this.
In the 660 days I had observed a difference between the 'drag and drop' points and points that were named points. That wa the start of me just getting to grips of how the Zumos navigated routes and dealt with missed points. The 550 that I had was very determined to visit certain points, the 660 less so. Then I got an offer I couldn't refuse based on swithcing out the 660 for the 590. And I never did find out fully how the 660 worked - although I have some notes.......
So when the 590 arrived, I wanted to test the same sort of thing. That lead to the observations that are still present throught the 590, 595, 39x and 34x.
If you have
S1 S2 V3 V4 S5 S6 S7 V8 S9 and you have reached V4, then you detour and rejoin the route between S6 and S7, the Zumo will navigate you ahead to S7. Until you rejoin the route between S6 and S7, the satnav will continue to try to take you back to the first missed point - you had passed V4, so it was trying to get you to S5 when you had to deviate - so it is still trying to get you to S5.
This is observed differently if you turn off automatic off route recalculation. The satnav goes quiet when you go off route. Not a word. When you approach the magenta line between S6 and S7, the instruction as you approach will be to turn towards S5. But as soon as you head towards S7, it will navigate you ahead.
You are not allowed to miss out a Via. So if you do the same thing from between V4 and S5, but instead, rejoin the route between V8 and S9, the satnav is still trying to get you to S5 - and that is in a different section of the route. So it will continue to navigate you to S5. It will not let you continue ahead. If you press SKip, then you will see that S5 is the next one in the list. If you go back to between S7 and V8 and then face the direction of V8 - then it will navigate you ahead to V8, then on to S9.
An odd observation.
I have noticed that when I bypass shaping points like this, then the 'skip list' - ie the points that shown when the skip button is pressed, still retains S5 as the next point. Even though I have joined the route and it is heading for S7, and it is quite happy for me to continue.
I couldn't work out what was goin gon here, and when I got home just before the end point - I checked the skip list and every single point that I had passed through was still there. I skipped each one turn.
I didn't understand this. I still don't. I just have a flag that says that the XT is behaving slightly differently. But I tested the behaviour that I described in my first two sections of this reply - and that behaved exaclty as I had said.
But something off had happened on that route. I passed through my start point after setting off, but the XT didn't seem to acknowledge it. I skipped the start point, and it seemed to be heading for the next point. It was doing everything correctly in terms of navigating me ahead, but th skip list wasn't being cleared as I went through points. But we now know that skipping a route pont seems to create a completely different type of route. (I still think it behaves more like a track-trip).
This is still there in my head, and needs testing. But this was also the day when I came across the phantom Via Point. The point that the XT had inserted at my point of deviation. So I had a route which was subject to RUT behaviour. I suspect that my return journey may have been related to whatever was going on on that day. Now that we have the ability to nobble the mImport byte, it is one of the things that I want to retest.
Routes are best with a small number of Via Points that will definitely be visited. I don't use them for coffee stops. I use shaping points for that. I use Via Points on the main route after the coffee stop - so that I pass through the Via whether I stop for a break or not.
Peobody wrote: Fri Jun 23, 2023 5:12 pm
I always feel that I need to clarify whether the shaping point was created by either setting a waypoint to non-alerting or using the insert tool (or ALT key-'rubber banding". I guess I am uncertain about whether any behaviors are different between the two.
No - you may have picked up that from me. It is actually irrelevant whether a route point was originally created as a Waypoint or not.
When I got my XT, it came with v2.30 of the software (I think it was). I was intrigued by this new facility - Closest Entry Point - I wanted ot know what it did. It was in the same section as 'Select Next Destination' - and that headed only for the Via Point that you selected.
And it turned out that so did CEP. It just selected a Via Point for you - the one that was closest to your current position. I was most disappointed. I expected it to head for the closest point on the route and continue from there. It didn't.
There were a series of updates after that up to 2.90 and then to 5.90 - something like that.
Each update resulted in different behaviour. I spotted that it had changed so that it included Waypoints but not shaping points. Then I noticed that it would head for shaping points If they had first been created as Waypoints. Then it would head for any route point. But it still wasn't closest entry. That came next.
That development was interesting - and I thought that it was odd that they made a separate case for points created as Waypoints. All that matters is that it is a route point - via or shaping. And it occurred to me that maybe one of the programmers thought that a Waypoint was any route point - in the same way that MyRouteApp uses the term 'waypoint'.
So ever since then - if I am testing behaviour, I use 4 types of point. Via, Shaping and Vias and Shaping that have been first created as Waypoints. Mainly because if it is down to a programming fault, it might be the same person !!
The drag and drop method can land on a point that isn't showing on the map. If that point is in the BAsecamp database it may become a Via and it may be a waypoint. Insert doesn't always produce a shaping point.
I've got a link to a video I did showing this. I'll find it and add it to this post......(goes away).......
It is not quite what I thought - but it sort of demonstrates the 'landing on a waypoint' idea. Dunkeld Hilton Hotel about 1minute in.
Link
