Where are tracks stored?
Posted: Mon May 15, 2023 2:34 pm
by Bear
My Zumo 350 has CN2024.1 split between internal storage and a 32GB SD card. When I ask BaseCamp to read from the Zumo it gives me the choice of main memory or SD card but, since I fitted the card, no history comes out of it. Where is travel history stored: main memory or SD card and how can I diagnose the absence of it. It is turned on wherever it appears in settings.
Re: Where are tracks stored?
Posted: Mon May 15, 2023 3:27 pm
by sussamb
History is stored in internal memory, it shows as a track or tracks so ensure you're looking in the right place in BaseCamp
Posted: Tue May 16, 2023 12:52 pm
by Bear
Thanks for the info. Next time I use the 350 I'll see what I get back from it.
Posted: Tue May 16, 2023 4:26 pm
Typically, internal storage in the GPX folder.
Tracklog.gpx or CurrentTrackLog.gpx
However, it will not be recorded unless you have specifically asked it to when you first got your Zumo.
I don't know the menu of the 345/350 - but look in Settings, Device, Travel History.
Mine says 'myTrends, Tracks, Where I have been' Whatever yours says, it needs to be ticked.
