Polarity of power pins Zumo 350
For everything Garmin Zumo 345/350 related
Glacial
Post by Glacial »
Does anyone know, can anyone measure, what the polarity of the power input pins on the 350 is? That is, when looking at the back of the unit, is the positive voltage applied to the left pin or the right?
Bear
Been liked: 3 times
Re: Polarity of power pins Zumo 350
Post by Bear »
The positive pin, if you look into the cradle, is on the right. Here's a photo of the cradle connected to my F850GS with a multimeter attached. Don't worry about the voltage being a little high: the meter takers no load whereas the 350 will take an amp or so.
Glacial
Post by Glacial »
Many thanks, very clear
