Page 1 of 3
3D AM Adapter
Posted: Sat Apr 29, 2023 11:43 am
by Don
Having issues with this adapter not charging the Garmin Zumo XT. The unit powers up the Garmin when ignition is switched on and powers down when ignition is switched off but no charging icon showing on Garmin screen. I have seen an article on this forum about soldering a new variable voltage converter to the unit but have been unable to find this item. can anyone help?
Re: 3D AM Adapter
Posted: Sat Apr 29, 2023 12:26 pm
by Stu
It was me that figured out this solution
I am going out at the min but will reply more than likely tomorrow at the earliest with the info
Re: 3D AM Adapter
Posted: Sat Apr 29, 2023 1:51 pm
by Don
Thanks Stu, appreciate that.
Re: 3D AM Adapter
Posted: Sun Apr 30, 2023 5:38 pm
by Stu
@Don
You need something like this
https://www.ebay.co.uk/itm/194950043266 ... %7Ciid%3A1
its a stepdown converter from 12v to 5v and you will need a minimum of a 2A output too
On the 3DAM adaptor carefully remove the cover where the wire comes out and desolder the board thats fitted and swap it for whicher one you purchase
First though I would check you have voltage at the pins of the current adaptor and that its not an issue with the pins not making contact with the zumo
Re: 3D AM Adapter
Posted: Mon May 01, 2023 8:23 am
by Don
Morning Stu, thanks for that information regarding the part to purchase from eBay and also the information regarding the pins. are the two pins positive and negative? What do you do if the pins are not making contact? Kind Regards Don.
Re: 3D AM Adapter
Posted: Mon May 01, 2023 8:42 pm
by Stu
Yes you have a positive and a negative as for it not making contact I suspect you would need a new connector but not sure where you would get one from
Re: 3D AM Adapter
Posted: Tue May 02, 2023 7:55 am
by Don
Thanks Stu, you have been very helpful, I appreciate your help in this. Don
Re: 3D AM Adapter
Posted: Tue May 02, 2023 9:11 am
by Stu
Let me know how you get on
Re: 3D AM Adapter
Posted: Tue May 02, 2023 11:24 am
by Don
Hi Stu, have ordered 4 of the converters 5volts 5 amps from eBay, will let you know how I get on, thanks again. Don.
Re: 3D AM Adapter
Posted: Sun May 07, 2023 2:12 pm
by Don
Hi Stu, Soldered the new converter in today, still not showing a charge on the Zumo. Checked the voltage at the Garmin pins voltage showing 5.09 volts. Any help would be appreciated. Kind Regards, Don.
