Page 1 of 2
Zumo XT acquiring satellites
Posted: Fri Apr 21, 2023 6:32 pm
by MichaelT
Hi . My new Zumo XT has stopped acquiring satellites, therefore no routes are offered. The GPS simulator is turned off.
Any suggestions? Thanks
Re: Zumo XT acquiring satellites
Posted: Fri Apr 21, 2023 6:33 pm
by Stu
Hi and welcome to the forum
You have tried it outside havent you?
Posted: Fri Apr 21, 2023 6:41 pm
by MichaelT
I have used it for the last two weeks with no problem. Yesterday it stopped acquiring satellites
Posted: Sat Apr 22, 2023 5:47 am
by sussamb
I assume you've tried doing a complete switch off rather than just letting it go to sleep? Press and hold the power button until you get the option to switch off completely. Now try with the XT outside with a good view of the sky.
Posted: Sat Apr 22, 2023 10:44 am
by MichaelT
Still the same problem, seems others are having the same issue. i updated the software / maps via my computer and now it will not to navigate to anywhere. The garmin XT responses by saying I cannot navigate the route .
Posted: Sat Apr 22, 2023 11:16 am
by sussamb
Then next step is a master reset, just like any computer after an update this is sometimes required. If still nothing you'll need to contact Product Support at Garmin
Posted: Sat Apr 22, 2023 11:19 am
by MichaelT
Thanks . How do you do a Master reset?
Posted: Sat Apr 22, 2023 1:28 pm
by skellum
Just a thought, have you made sure that the TopoActive maps are still unticked?
Posted: Sat Apr 22, 2023 2:48 pm
by sussamb
MichaelT wrote: Sat Apr 22, 2023 11:19 am
See here
viewtopic.php?t=1577&start=10
Posted: Sun Apr 23, 2023 1:56 pm
by MichaelT
Hello again. Switching off the tick boxes for topo maps makes no difference . It can not find the satellites or a suggest a route .
Thanks for your support , I think I need to chat with Garmin as they had a similar issue about year ago according an earlier discussion on this forum.
