danham wrote: ↑26 Apr 2023 11:09
For what it's worth (not much, I fear), the zumo 660 is also listed as not compatible with BC. I have been using a 660 with BC for years until I got my XT and yes, on occasion it would cause problems, but in general, with careful checking of a route on the 660 before setting out and depending on it in the field, it worked OK.
Yes it does work, but can (as admitted at he time by Garmin) produce some weird navigation errors.
One issue might be to do with Basecamp, the 660 used 'Via Points' - but these are not the same type of Via Points that the 590 and later Zumos used. They were more like the Shaping Points. Garmin 're-purposed' term Via Point for use with the Zumos that have the Trip Planner App. I never had my 660 and familiarity with Basecamp at the same time, so I never found out.
I was the other way about - I hated Basecamp when it first came out - there was a lot to hate about it, and I continued to use Mapsource with my 590. Of course that didn't know about alerting Via points and non-alerting Shaping Points , and I was forced to switch. Fortunately Garmin put a lot of effort into getting it right. They didn't quite make it, but what bugs remain are trivial and BC is (still) far superior for the 590/595 and related Zumos than most other things around. Including Garmin's Explore and Tread. Any planning tool that doesn't have a computer version is going to lose out as far as I am concerned. I have a smartphone, I have an iPad - neither give me the accuracy that I need short of grinding my fingers down to something more pointy.
I don't know what happens with route points that are Vias and Shaping when the 660 receives them - does it just ignore them, or do you only use Shaping Points - or does it trat all points as the same type. I am just curious.
If ever I have the cash to spare and someone is getting rid of a working 660.....I'd have it back.
Links:
Zumo 590/5 & BC . . .
Zumo XT & BC . . .
Navigating with Zumo Booklet
