New version
New version
Minor update to BaseCamp, apparently to allow it to work with some newer devices, no change in functionality as there is no further development of BaseCamp
BaseCamp software version 4.7.5
as of March 27, 2023
Download (61.93 MB) here https://www8.garmin.com/support/downloa ... 5#Instruct
Notes:
System Requirements:
Windows 7 SP1 or later is required. Machines with earlier operating systems can use BaseCamp 4.2.5.
.NET framework 4.6 is required. A current version of .NET will be installed if needed.
1 GB of system memory is required, 2 GB of system memory is recommended when using BirdsEye Imagery or Garmin Custom Maps.
A video card that supports OpenGL version 1.3 or later is needed to enable the 3D view.
If you experience problems when interacting with the map views, please make sure that you have installed current video card drivers.
BaseCamp will recognize all MapSource products except BlueChart.
BaseCamp does not work with serial GPS devices.
Change History
Changes made from version 4.7.4 to 4.7.5:
Various stability and bug fixes
Re: New version
I wonder if this minor fix is to cure the major issue that we have been experiencing.
eg routes transferred from Basecamp get wiped at the next transfer.
Routes transferred from Basecamp have the names of route points changed
Routes transferred from Basecamp are prone to get stuck in a RUT. Routes created on the XT using the same points, are not.
I will be looking at this with some interest, and I will make sure I keep my previous installation files to compare.
Thanks @Stu Fingers crossed.
Has liked: 436 times
Been liked: 264 times
Re: New version
jfheath wrote: Tue Apr 11, 2023 5:06 pm Thanks @Stu Fingers crossed.
I think you was meant to tag @sussamb :lol:
Re: New version
Oops. Sorry @sussamb . Tagged belatedly.
Has liked: 203 times
Been liked: 286 times
Re: New version
Could this update be related with the new XT2?
Re: New version
Anything is possible but unlikely
Re: New version
The new XT2 info says that it does not connect to Basecamp, so I doubt it !
I'll see if I can find where I read it.
Has liked: 147 times
Been liked: 139 times
Re: New version
Garmin Automotive Devices
zumo XT2
To view and share your data, use the Garmin Tread App. BaseCamp will display "Unsupported Device Connected".
This can be found here:
https://support.garmin.com/en-US/?faq=O ... jPUxBWrQQ6
Re: New version
Mistery solved. Thanks.
Re: New version
Apparently, (I don't know), the message appears and then it connects. But what it does with the data when you try to send it from BC, I wouldn't know. Nor do I want to find out.
