Identical Maps?? Garmin Zumo 595LM 95% Full!
Re: Identical Maps?? Garmin Zumo 595LM 95% Full!
You can move the map folder to the Garmin folder on the card. Move the JCV folder there too. If you delete it you'll lose junction views. For the SID folder you won't gain much so just leave it, you can clear our the older files if you have a lot there but leave the latest one of each type.
- Has liked: 18 times
- Been liked: 1 time
That's interesting. I'm not able to delete routes via Basecamp from the internal memory. Basecamp doesn't even give me that option.
Zumo XT2, Zumo 595LM
2011 Harley-Davidson FLHTCU
1993 Harley-Davidson FLSTF
Do you mean BaseCamp or Windows Explorer? As far as I'm aware BaseCamp can't delete data on 'on the road' devices.
- Has liked: 105 times
- Been liked: 232 times
Ok, clarification:
On the device, I delete all routes and saved points I don't want to keep. Then hook to Base Camp, making sure Garmin Express is shut down completely, i.e., not running in the background. When I do this, by clicking on internal or user memory, I can see all the waypoints saved as favorites and all the routes and points in user memory. I delete or copy-then-delete anything I don't want to keep.
Ease of management is one reason my routes all get put ONLY on the SDcard and never transferred directly to the device.
What is a junction view?sussamb wrote: ↑15 Mar 2023 06:54 You can move the map folder to the Garmin folder on the card. Move the JCV folder there too. If you delete it you'll lose junction views. For the SID folder you won't gain much so just leave it, you can clear our the older files if you have a lot there but leave the latest one of each type.
Maybe the 590 is different than the 595 in that the Map folder is not in the Garmin folder. I simply moved the Map folder to the sd card and it seems to work fine.
Ah ok so it's only on the card you're deleting data using BaseCamp, that makes more sense.rbentnail wrote: ↑18 Mar 2023 00:07 Ok, clarification:
Map folder whether in .system or not can be moved to the card. As for junction view:Iris wrote: ↑18 Mar 2023 02:31What is a junction view?sussamb wrote: ↑15 Mar 2023 06:54 You can move the map folder to the Garmin folder on the card. Move the JCV folder there too. If you delete it you'll lose junction views. For the SID folder you won't gain much so just leave it, you can clear our the older files if you have a lot there but leave the latest one of each type.
https://support.garmin.com/en-GB/?faq=U ... ve%20route.
- Has liked: 1 time
Great info on this thread, I was able to reduce the % full almost exactly to the same values as the OP.
One correction needs to be made, back on Page 2:
"Note that the .System folder does not show up in MTP mode. It only shows in Mass Transfer mode. So if you know that you want access to it, turn on the Zumo, go to the hidden system diagnostic page and set it to be Mass transfer (or Mass Transfer Single Session). Then click 'Save' and plug in the USB cable."
I believe the word "transfer" should actually be "storage", as that is how it is mentioned above this part of the instructions.
- Has liked: 389 times
- Been liked: 847 times
Yes it should. Thankyou for spotting that. I have corrected the original post. At least I was consistent in that sentence. I made the same error three times - but nowhere else. My brain must have gone walkabout while I was typing.jmdaniel wrote: ↑02 Apr 2024 16:56
Mass Storage mode - Acts like a disk drive, has drive letter, must be 'ejected' before disconnecting. .System is visible.
MTP - Media Transfer Protocol. Appears without a drive letter - just a name. No need to eject. .System not visible.
- Has liked: 1 time
No worries, I thought I knew what you meant, but with the mysterious nature of all things Garmin, couldn't be sure. Unrelated, but I spent a couple of days last week, trying to figure out why my Sena 50S wouldn't work with either my 595LM or my 550. As it turned out, I needed to remove both the Sena and my phone from both, then re-add them.
Always a mystery...
