Hi
Can someone confirm this method is not working on an XT? (it works on my 390).
The XT is completely garbled with a mix of maps, probably due to an error during update.
Soft reset or reset from the menu systems does not do any difference on the XT.
br Lars
Factory Reset, Right Corner - Power On not working?
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Re: Factory Reset, Right Corner - Power On not working?
Have look here, see if it helps https://support.garmin.com/en-GB/?faq=G ... q7Rd9vj82A
Thanks, but was already tried. Does not delete maps.
- simoncrewe
Lars, I think you may have confused us all! Your original post did not mention deleting maps, as 'sussamab' pointed out a factory reset never deletes maps.larsras wrote: Mon Aug 08, 2022 7:20 pm Hi
br Lars
If you want to delete maps off the unit you will need to do that with the XT connected to your PC/Mac. Just be careful what you delete, as it is easy to introduce problems whilst deleting files.
To delete maps try GMTK https://www.javawa.nl/gmtk_en.html
