Yes, that's true, but only in Base Camp!!!!!! Device routing calculating and Base Camp routing calculating behave differently!! When you transfer the route from Base Camp to your device, that device has its own calculation algorithms that are separate and different from Base Camp's. This is the point I'm trying to make- what you see in Base Camp is not necessarily the same thing you are going to see on your device.
This used to drive me crazy with my nuvi, with my 595 and with my XT. The routes that I would see on my device rarely matched what I was looking at in Base Camp, and in Mapsource before that, and in 3 or 4 other routing apps- I could never get them "to work right" on my gps device. It wasn't until I began adding more points so that my device had no choice but to follow the route I was giving it that it actually worked the way people were telling me it could work. Until then, for me, the device was nothing more than a fancy road map.
It takes a little time & practice and for me a lot of patience to learn the differences between Base Camp and device routing and how each differed from the other. I'd make a route in Base Camp and all looked good. I'd transfer it it, import it and view it and rarely did it match what I was looking at on my computer in Base Camp. I was extremely frustrated that it never once worked like people worldwide said it did. Leave your points in and if necessary add more points. I understand the need to "tidy things up" but eventually, like me, the need for correct routing overrides to need to look pretty
