CN EU 2023.10 NTU
Scarecrow
Been liked: 25 times
Re: CN EU 2023.10 NTU
Post by Scarecrow »
wessie wrote: 22 May 2022 15:32
Scarecrow wrote: 22 May 2022 15:27
sussamb wrote: 22 May 2022 12:29 @Scarecrow
Have you tried deleting the downloaded map data already on your PC? Think you'll need to do that first, at least I did and it then worked.
Sorry Sussamb
I'm not That computer literate
but HOW do I delete the downloaded map data
It will show as an installed programme in Windows settings. Go to "Add/Remove" programme in settings. Simply type "add/remove" in the search box at the bottom left of your screen and follow the instructions
Thanks Wessie
I think that's sorted it
Raf
Has liked: 14 times
Been liked: 3 times
Italy
Post by Raf »
Where can I find the previous V. ?
wessie
Wales
Post by wessie »
Raf wrote: 23 May 2022 17:04 Where can I find the previous V. ?
if you have installed maps to Basecamp on a PC or Mac then the old version should be available, as I state above. It will need to be a version of the maps previously unlocked to your Zumo using Garmin Express.
Raf
Has liked: 14 times
Been liked: 3 times
Italy
Post by Raf »
2022.20 unlocked.
I can't find where the "only on pc" option is
wessie
Wales
Post by wessie »
Raf wrote: 23 May 2022 18:44 2022.20 unlocked.
there is an option in Garmin Express to copy the maps currently on your device to your PC. Click "map options"
However, if you did not do this when 2020.20 was the current version, then you cannot get them now.
Many people do not use Basecamp but my recommendation is to at least install map details on a PC/Mac as a back up.
Raf
Has liked: 14 times
Been liked: 3 times
Italy
Post by Raf »
I will use the BMW Nav VI to install on pc only
