CN EU 2023.10 NTU
Scarecrow
Been liked: 25 times
Re: CN EU 2023.10 NTU
Post by Scarecrow »
as earlier post I had to revert to earlier GE
I've tried it on my second PC and it still wont load maps to PC with GE 7.13.1 for some reason
wessie
Wales
Post by wessie »
If you have older versions of the maps on a laptop or PC then Basecamp can install maps from this dataset. You just select the map version and the tiles to upload. Hold the mouse button down and drag the cursor to select multiple tiles. Right click to unselect a tile. It takes ages but I have UK, France & Spain back on my device from the 2022.22 maps. I had over half of the internal memory available, so sufficient. If you lack space then I assume you can use an SD card.
Scarecrow
Post by Scarecrow »
ok still having problems loading CN EU 2023.10 onto 2nd computer
anyone know where i can find GC 7.12.1 to download
Has liked: 420 times
Been liked: 235 times
all working fine here on device and PC :)
Scarecrow
Post by Scarecrow »
This is doing my head in
I have managed to download map update to PC but its now saying maps are locked
CAN ANYONE HELP PLEASE
Has liked: 350 times
Been liked: 371 times
I got that at first. Solved by updating Express to v7.13.1
Scarecrow
Post by Scarecrow »
sussamb wrote: 22 May 2022 06:34 I got that at first. Solved by updating Express to v7.13.1
Done that too
@Scarecrow
Have you tried deleting the downloaded map data already on your PC? Think you'll need to do that first, at least I did and it then worked.
Scarecrow
Post by Scarecrow »
sussamb wrote: 22 May 2022 12:29 @Scarecrow
Sorry Sussamb
I'm not That computer literate
but HOW do I delete the downloaded map data
wessie
Wales
Post by wessie »
Scarecrow wrote: 22 May 2022 15:27
Sorry Sussamb
It will show as an installed programme in Windows settings. Go to "Add/Remove" programme in settings. Simply type "add/remove" in the search box at the bottom left of your screen and follow the instructions
