XT charging & 40% brightness issues
JS_racer
Has liked: 9 times
Re: XT charging & 40% brightness issues
Post by JS_racer »
Fxwheels wrote: 23 Feb 2023 16:30
Hopsngrains wrote: 06 Aug 2022 17:44 I may consider another mount idea, using the USB, as when I connect this cable it does charge.
Right.
I had the same set of issues on my bike ST1300 (Pan European). I also got the 40% issue on a rented BMW in Spain and my old backup Nuvi 1450 saved my day.
At home, my solution was connecting the nav via USB cable to a USB 2.0 plug wired to an ignition vires. No power loss issues anymore.
the output of the usb adapter needs to be 2.0a or more, then no issue..
I use it in the car on a dual 2.4a adapter, to usb cable. full charges the gps running up to 17 hours with no issue.
tried it on the bike with a 1a, dim screen after X time , swapped adapter on the bike to a 2a, perfect.
Has liked: 146 times
Been liked: 452 times
JS_racer wrote: 04 Mar 2023 15:32 tried it on the bike with a 1a, dim screen after X time , swapped adapter on the bike to a 2a, perfect.
Interesting. I had this problem while using a dual 2.4 amp cigarette lighter adapter on my Goldwing. I had to wire the Garmin mount. I also had the same problem when trying to use the XT in my car (2.1 amp cigarette lighter adapter). I have since learned about charging (power only) cables and have purchased one for the car but have not tested it.
