Re: Travel planning tips – Basecamp and Zumo XT
Posted: Mon May 09, 2022 1:06 pm
Is there a way to change Waypoints to Shaping points or Shaping points to Waypoints in Basecamp en masse?
Dedicated forums for Garmin Zumo motorcycle satellite navigation. All questions answered from problems, route planning, touring to tips and tricks
https://www.zumouserforums.co.uk/
Ah, yes I did say that first statement. That was because every single route point in my route had been created as a Waypoint first. So in that context I was correct. I was being deliberately provocative as I know that some people think of Waypoints as being Via Points and don't realise that a Waypoint can be made into a non-alerting Shaping Point.
Well, thats not a bad idea, but if the reason that they gave you that "only Waypoints can be selected should you need to return to a route" is wrong.Peobody wrote: ↑Mon May 09, 2022 5:12 pm What are your thoughts about creating Waypoints for stops, generating a route using those waypoints, and then using the Insert tool to form that route as desired? I have been discouraged from doing so by fellows riders who use Basecamp because only the Waypoints can be selected should you need to return to a route. Neither of those guys had a device that had the "Closest point" option like the XT does so maybe their thinking was relevant to their devices but not to the XT.
Actually, they believe that once you change a Waypoint to a non-alerting point that it is not available to select as a destination on the device similar to points created using the insert function. I have never tried to route to a non-alerting Waypoint nor have I ever looked to see if they are in the Saved (Favourites) list.
I'm pretty sure that when they say "waypoints" they mean shaping points. Right, these points which you shape the route based on, so Garmin will stick to the planned route. These are non-alert points and are a blue dots in Garmin.Peobody wrote: ↑Mon May 09, 2022 10:08 pmActually, they believe that once you change a Waypoint to a non-alerting point that it is not available to select as a destination on the device similar to points created using the insert function. I have never tried to route to a non-alerting Waypoint nor have I ever looked to see if they are in the Saved (Favourites) list.
They believe a lot of Waypoints are required to insure the integrity of the route in the event of a recalc. I agree with them on that.
I'm going to re-ask your question the way I think you are asking it, tell me if I'm correct:
That is absolutely correct, Russ.rbentnail wrote: ↑Tue May 10, 2022 10:41 am I'm going to re-ask your question the way I think you are asking it, tell me if I'm correct:
Is there a way to change VIA points (alerting) in a route to SHAPING points (non-alerting), or vice versa, in Base Camp en masse?
The answer is yes. In Base Camp, with the route options box (with the either VIA or SHAPING points listed) open, click on the second one in the list to highlight it. Scroll down to the 2nd to last point in the list and SHIFT+CLICK. This highlights every point between the 2 you picked. Right click, select 'Don't Alert' to change all to SHAPING or 'Alert' for VIA. You can do this for any number of points except the start & destination points.
To pick just a few points, the normal CTRL+CLICK does not work like everywhere else in Windoze but SHIFT+CLICK does, go figure.
