Satnav bracket
Pockets
Satnav bracket
Post by Pockets »
Hi, Been a while, so my latest project is to mount my 550 onto a satnav bar above the clocks on my bike. The problem being I cannot find the right backing plate to fit my mount. I want to fix it directly to the bar without messing with ball mounts. The backing plate just needs to have a recess to fit around the mounting bar and four holes to except the screws from the charging unit.
Does anyone know of such a backing plate or something i could use.
I await your invaluable knowledge.
Re: Satnav bracket
I'm having a hard time picturing your description.
wks
Has liked: 27 times
Re: Satnav bracket
Post by wks »
Ebay?
120985213336
I think I done that correctly
Bill
Another one
125116249087
Pockets
Re: Satnav bracket
Post by Pockets »
Right lads thanks for the reply’s, I’ve just looked at the suggestion by wks (Bill) and I’ve come across this 124506736106 and if the holes are in the right place it should do the job. I’m waiting until it stops raining so I can go in the garage and measure it. But it looks promising, just hope my satnav bars is 22mm.
I’ll be back.
