Hi Totti,
I have the Garmin cure file and the GCD (firmware) file for a 395LM.
Let me know your email and I'll send them over to you.
Colin.
395LM Stuck in boot loop
Re: 395LM Stuck in boot loop
Just sent you PM.
”On se kumma kun tehdään kunniaa sille joka löi jalkansa poikki.
Vaan se jolla on päässä huminaa, sitä poloista häpeää kaikki.” Timo Rautiainen & Neljäs Sektori
Got mine working again!
I was able to download the firmware from Garmin website and the "Garmin Cure" from the gpspower-forum.
It was a bit of a pain to get the timing just right with the preboot-mode.
Unlike in "daniel87"'s case, I got an error when trying to launch the "updater.exe" from "Garmin Cure".
Noticed that it made a temp folder under the folder it was ran. Moved the "updater.exe" -file to this folder and ran it from there without any problems.
The "cure" option in "Garmin Cure" worked fine, but the "original" option did not work. It jammed the device.
Finally I ended up formatting the whole device using "RMPrepUSB" software and installed new firmware with the "Garmin Cure".
This trick worked and now the device is working properly!
I copied all the files from the Zumo before formatting. This was a good thing, because I was able to copy back the right language and keyboard files.
Did not install any Garmin-maps, because for some reason this take hours to finish.
Running the device with osm-maps and maps from the National Land Survey of Finland.
Hi
My 395LM stuck in the boot loop after updating the maps.
I have read the discussion, what I can't find on the internet is the GCD (firmware) file for the 395LM. All links do not work.
Does anyone have the firmware for me?
Hi,
I have a copy of the firmware. If you pm me your email and I'll send it to you
Hello
I just need the Garmin cure 3 program. I cant find it anywhere to download. Please someone put a link
Did you get the firmware? I downloaded mine from this address : The spelling and capital letters needs to be exactly the same.Hansmuster wrote: ↑23 Jul 2023 22:11 Hi
Hope this helps!
- Has liked: 29 times
- Been liked: 75 times
Just click the link, save some typing:
https://download.garmin.com/software/Zumo3x5_460.gcd
Sena20S<>Zumo XT< >Galaxy S10
