Saving Route to folder on desk top
Posted: Wed Jun 16, 2021 6:32 pm
by Scarecrow
Ok Guys
I've tried a search but cant find the answer
can i save routes and way points to a folder on my desk top
rather than just keep them in the collections folder on basecamp
Cheers
Del
Re: Saving Route to folder on desk top
Posted: Wed Jun 16, 2021 9:25 pm
by rbentnail
You most certainly can! I do it all the time. Here's how I do it:
- I went to my Documents and made a new folder and named it "Base Camp Routes and Points".
- in the Base Camp (BC) info box, I highlight the route or point I want to EXPORT. I pick one at a time rather than picking a whole list.
- In BC, select FILE at the top then EXPORT then EXPORT SELECTION. Navigate to your newly made folder in documents and save it.
Do you know how to make a shortcut icon on your desktop so you can go to your new folder quickly?
Posted: Thu Jun 17, 2021 4:44 pm
by Scarecrow
Simple Thanks
err, How do i import them back to Basecamp
Posted: Thu Jun 17, 2021 7:33 pm
by rbentnail
Why would you need to import them back? Exporting saves a copy per se, it does not remove the route or waypoint from Base Camp.
But if come across other peoples' route you may want to import, under the FILE command in BC there's an IMPORT option too. Select an existing LIST FOLDER to put it in, then FILE/IMPORT INTO list folder name.
Posted: Fri Jun 18, 2021 4:21 pm
by Scarecrow
Brilliant thanks
Wanted to be able to import to another PC
