Not routing properly with OSM Street maps
Posted: Fri May 28, 2021 6:15 pm
by Triplog
Has anyone found that the XT will not route properly with OSM Street Maps?
When I activate these maps I lose Distance to Next Turn and Speed Limits. If the route includes a Waypoint I can't get past that! The unit keeps trying to route back to that point, even trying to skip the waypoint leads to odd random routing.
Re: Not routing properly with OSM Street maps
Posted: Sat May 29, 2021 8:27 am
by sussamb
Probably the map, some OSM maps cause issues.
Hardly any I use for example include speed limits, if you use OSM maps you can't expect them to work exactly like Garmin maps
Posted: Sat May 29, 2021 8:38 am
by Rofor
Hmm, first question for problems with 3rt party maps - did you disable the original City Navigator street maps under 'MyMaps' on the Zumo XT?
Two routeable maps activated at the same time makes for sure troubles...
Posted: Sat May 29, 2021 1:53 pm
by sussamb
Very true. I wondered once why my Garmin map wasn't working normally then found a recent software update had enabled an OSM map I also had loaded
Posted: Sun May 30, 2021 6:45 am
by Triplog
Thanks for the replies. Yes I'd tried disabling the CN standard maps - no difference. Seems to be as Sussamb suggested - third party maps just throw wobbles! From now on I'll stick to the standard maps when routing through anywhere new and use topo maps when just bimbling about! Every day's a schoolday!
