Road colors by type
Posted: Thu Apr 22, 2021 3:47 pm
by Francis
I don't remember how it was last year, but after updating to fw 5.90, the colors of the roads in the navigation map are always the same, they do not change according to the chosen theme.
Theme colors change only when previewing and with great zoom-out.
Samples for Suomi:
Samples for United Kingdom:
Re: Road colors by type
Posted: Fri Apr 23, 2021 10:14 am
by Francis
Supplementary infos: the problem only if the Usage mode is the Motorcycle. If the Usage mode is the Car, colors are OK.
Posted: Sun Apr 25, 2021 11:15 am
by Francis
For the example here are screenshots, in both modes (Motorcycle and Car) is the same Theme, with the same colors.
In the Motorcycle mode Garmin ignore my colors and use some own default.
Posted: Sun Apr 25, 2021 8:00 pm
by Francis
Solved.
I had turned on the topo-map in the motorcycle profile. Colors are OK after turn off topo map.
