Garmin express V6.6.0.0
Has liked: 435 times
Been liked: 260 times
As above
Now available!
Get more updates for Express than for the device and basecamp :lol:
kernowing
Has liked: 135 times
Been liked: 61 times
Re: Garmin express V6.6.0.0
Post by kernowing »
Updated, thanks Stu.
2007 GL1800 Goldwing
Zumo 660LM
dave726
Has liked: 5 times
Post by dave726 »
Garmin Express Release Notes
06-28-2018, 12:14 PM
Garmin began rolling out Garmin Express v6.6.0 for the PC today. If you would like to update to the latest version, please visit the About page within the Settings of the Express application and select “Check for Updates to Express.” This version includes the following changes:
• If you’ve purchased a map from a vendor that contains a voucher code, the code can be redeemed through Express to activate and download the map.
• It’s always best to keep Garmin Express up to date with the latest version. Express will now provide an alert when a new update is available. This will allow you to know right away and not have to depend on going into the Settings to check for updates.
• Other minor bug fixes and improvements.
Previous Versions:
6.5.0
Express indicates a new device has been connected by displaying a banner. Also, for users who have had to send in their device and received a replacement, Express will detect that it’s the same model of device and ask if you’d like to replace the already added device or add it as a new device.
• Improvements have been made to the Help Pages for adding a device.
• Fixed an issue that could cause the time to change on a Forerunner 645 after being synced.
6.4.0
• Added the option to use your iTunes Library to manage music within Express.
• If a user backed up their favorites from an older Automotive device into Express, the file would go to the incorrect location and not appear on the new device when it would get transferred. We fixed this issue and now the file for your favorites will transfer to the correct location.
6.3.0
Music files would not be included with the transfer of a playlist that was exported from iTunes. This was causing an error and has now been resolved.
6.2.0
Users can now add a Monterra to Express if there is a SD card inserted.
For Approach S1 users, we fixed an issue that would not allow the user to change courses following an update.
Helped address an incorrect cycle map part number being installed to the Fenix 5x for AU/NZ users.
6.1.1
The vívofit jr. and jr. 2 can no longer be added to Garmin Express.
6.0.0
With the announcement of the Forerunner 645M, Express is now setup to support transferring music files from your computer to the device.
Minor bug fixes and improvements.
5.9.0
5.8.0
BlueChart content is now accessible for handheld devices, such as the GPSMap and Montana’s.
Added support for the fitness devices with CIQ favorites.
Fixed the progress indicator for map reinstalls so that it will reach 100%.
Fixed a failure for Cycle Maps installing to fenix 5x and D2 devices.
5.7.1
Fixed an issue with the ?Shop for Charts? URL not directing users to the correct locale.
5.6.2
Fixed a failure that would occur when attempting to reinstall a CourseView map.
5.6.1
Fixed an issue where users were prompted with ?Cookies Required? when attempting to sign into a Garmin Connect account via the Facebook widget.
Fixed an issue for an error that would occur when attempting to reinstall a CourseView map.
Fixed an issue that could cause a user to get stuck in a spinner state during the ?Preparing? phase of a map updates
5.5.0
Fixed an issue with non-Marine preprogrammed map cards displaying as an Invalid Chart on the Device Found page.
5.4.1
Fixed an issue causing syncs to fail.
5.4.0
5.3.1
• Fixed an issue when the install flow would not show progress for safety camera updates.
• Fixed an issue where an incorrect banner would display after downloadable content was downloaded.
• Fixed an issue when there wasn’t enough free space on the computer, the minimum amount of free space needed would be blank.
5.3.0
• Minor improvements and bug fixes.
5.2.0
• Added Vietnamese Language support.
5.1.1
• Fixed an issue where Express could crash when attempting to add a device
5.0.0
sigpic
Sleuth
Has liked: 14 times
Been liked: 16 times
Belgium
Post by Sleuth »
Thanks for the notification
Maps: Europe NTU 2024.10
