Cradle - device connectror pinout ?
Posted: Fri Apr 02, 2021 3:58 pm
by Narsil
Hi,
So I need to pick the +12V/Gnd pins on the cradle connector (I want to build a smartphone holder -with Qi charger- out of a spare cradle cove)
I found somewhere on the net the attached diagram showing 15-16 as gnd and 17-18 as pwr pins.
But on my cradle, I don't find any voltage between those (supposing 18 is up and 1 bottom), and to be clear, when I insert the GPS (595LM), it does light up and charge, so there is power somewhere ...
What do I miss ? Can someone help me ?
Diego
Re: Cradle - device connectror pinout ?
Posted: Mon May 31, 2021 3:51 am
by UrbanNomad
Did you manage to figure this out? My cradle isn’t charging the Zumo 595 anymore and before i open up all the fairings etc to get to the bullet connector on my bike, thought I’d check the voltage on the cradle and see if the tightness / connections were an issue or was it in the power supply at the bullet connector..
Posted: Mon May 31, 2021 9:04 am
by Narsil
Nope, I have opened a ticket at support, waiting for an answer (if ever)
Posted: Mon May 31, 2021 7:54 pm
by UrbanNomad
Oh man… do post back in case you get a reply.
