Re: Dusted off the 660.
Posted: Tue May 12, 2026 9:51 pm
Never mind dusting the 660 off I've had to dust off this thread now!
As usual, life tends to get in the way of things and I haven't been able to ride my bikes as much as I'd planned and so hadn't done anymore with my sat nav. But following riding recently I've decided to do something about it.
Having recently replaced the PC the first job was to reinstall Garmin Express and Basecamp during which I was surprised and happy to see that I could update the maps which I couldn't do when last posting and also install to the PC/Basecamp which I also couldn't do. OK, it's CN Europe (well part of it) NT 2025.1 but that will do me as many years younger than my existing maps! When installing, at 54% I received an error message signalling an update failure but on checking the 660 the maps seemed to have installed OK and I read somewhere that these messages aren't unusual? We shall see.
Other thing was to 'butcher' the sat nav harness as there was no way I wanted it as standard on my Scrambler. I say butcher but you have to be more gentle than that, well in some ways! First job was to cut off the unwanted additional leads and splitter connector as I only wanted power. I then cut back the cable and cut back all the non-power cables and removed the sheathing etc. I cut these cables to different lengths to avoid any shorting and covered in heatstrink. I then soldered a short length of smaller diameter twin-core cable to suit the entry of the right-angle male connector used on the Tiger 1050. This was a slight mistake as when checking on the bike decided that a straight connector would be better. Fortunately I had a straight Powerlet in the box from when I'd originally bought the sat nav, so no delay there. The cable diameter was a little too small so I built it up with layers of heatstrink.
With this done I should be good to go but I decided to have a look at the links kindly provided by another member. Both had opened up the cradle (which I'd done in the past) so I did this again. I didn't want to disturb the cable entry as they'd done but whilst I'd staggered the redundant cables I thought I'd make doubly sure and remove the plug on the circuit board and cut the cables off. With this done I put it back together. Unlike with a lot of things nowadays you can easily take the cradle apart.
Fitted it and the sat nav to the bike and nothing! Slight twist of the Powerlet though and it powered up, brilliant! Might just need a bit of a clean as it seems to be good quality and made in Germany. Failing that I'll get another or use the right-angle one.
Just need to remind myself how to use Basecamp again now! Good to see that the 660 is still being discussed. I did briefly think about getting another sat nav but no real point really as I really like the 660 and it does everything that I want and is in first class condition, well apart from the harness!
Chris
Chris
