Has liked: 39 times
Been liked: 97 times
Germany
Post by proofresistant »
turbo19 wrote: Thu Oct 09, 2025 5:55 pm It syncs well for me too, but the XT2 resets every 10 minutes or so.
Have you checked, for example with TripManager, whether you have multiple identical routes in the device?
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Post by turbo19 »
proofresistant wrote: Thu Oct 09, 2025 6:01 pm
I will try this. Thanks for the advice. I have many offroad tracks.
Dutchgixxer
Has liked: 13 times
Been liked: 27 times
Post by Dutchgixxer »
I have sended 9 routes 9 tracks and 100 waypoints. No troubles no reboots so far.
Has liked: 39 times
Germany
Dutchgixxer wrote: Thu Oct 09, 2025 7:41 pm I have sended 9 routes 9 tracks and 100 waypoints. No troubles no reboots so far.
Sounds good.
Imported routes?
If so, which source program?
How many kilometers?
How many shaping points?
PS
I just did some more tests.
For some route sections, I changed the calculation profile or “only” changed the colors.
Some parts came through, others were lost (remained unchanged in the device).
Dutchgixxer
Has liked: 13 times
Yes routes and tracks approx 270 each ever 3 -5 km a shaping point to ensure force te route to get routes as i have planned.
Source basecamp
Has liked: 39 times
Germany
That sounds good again.
I don't have that many shapers.
Who knows, maybe that's why it works so well for you, but so many shapers are not an option for me; my Tread 2 doesn't like more than 30 shapers between a VIA either.
Nevertheless, the synchronization has problems :-(
If anyone else has their XT2 refusing to be seen by Garmin Express / the PC as a drive?
Tried different cables, different ports on the laptop, a soft reset on the XT2, turning off the laptop, but the XT2 refuses to go past the bright screen with the "Garmin and garmin.com/express" screen.
Took out the micro SD card I had installed and instantly it connects.
Has liked: 39 times
Germany
Oop North John wrote: Sat Oct 11, 2025 11:13 am Took out the micro SD card I had installed and instantly it connects.
Interesting observation. Good to know.
I hope this is an exceptional situation.
Perhaps it's “only” the SD card that's defective. Keep in mind that the zumo XT2 also makes the contents of this SD card available to the PC.
I would recommend:
1. Starting a new topic/separate thread for this ;-)
2. Checking the SD card on the PC.
I have no idea what to look for, but there may be some kind of issue there.
turbo19
Andorra
Post by turbo19 »
Could someone confirm for me if the reboots continue with version 6.10 of the XT2 and the Tread with version 2.12.33?
In my case, they continue, and it's necessary to stop the Tread app so that the XT2 doesn't keep rebooting. :roll:
King
Italy
Post by King »
Oop North John wrote: Sat Oct 11, 2025 11:13 am If anyone else has their XT2 refusing to be seen by Garmin Express / the PC as a drive?
I had to replace the original cable because I suddenly couldn't connect it to my PC. This was very strange because it had always worked for over a year. However, after replacing the cable with a regular one I used for my smartphone, everything worked fine.
