Page 22 of 26
Re: Introducing TripManager
Posted: Wed Mar 04, 2026 7:03 pm
by FrankB
Basecamp will popup a message that the XT3 is not officially supported. (Like the XT2)
You can transfer routes/track/waypoints to the XT3 from Basecamp. But you can not delete them from the device using Basecamp. That has to be done on the unit.
Also beware that if you have Tread enabled and allowed to sync, your routes will be modified. Just like with the XT2
Posted: Wed Mar 04, 2026 8:24 pm
by FrankB
Version V1.7.0.380 released
The most exciting new feature of this version, at least for me, that the
XT3 is supported. Of course this new model will need extensive testing, but first impressions look good.
The full changelog can be found here:
https://frankbijnen.github.io/TripManag ... story.html
The release can be downloaded here:
https://github.com/FrankBijnen/TripManager/releases
Frank
Posted: Wed Mar 04, 2026 10:10 pm
by Peobody
@FrankB , do you recommended uninstalling a previous versions of TripManager before installing a newer one?
Posted: Wed Mar 04, 2026 10:17 pm
by FrankB
Peobody wrote: Wed Mar 04, 2026 10:10 pm
It's up to your preference. It should work without uninstalling, and with uninstalling.
Note that any settings you have made are always retained. As in: They are not uninstalled.
FYI: The settings are stored in the registry under: Computer\HKEY_CURRENT_USER\Software\TDBware\TripManager
Posted: Wed Mar 18, 2026 9:09 am
by Oop North John
One query, if you have the Tread app active and "enable sharing" active, does Tripmanager and Tread being active conflict with each other?
Today I'm disappointed (trying to be very polite there) with the Tread app, it can't calculate routes, even though you can see on the graphics it knows which roads it is going to use.
Posted: Wed Mar 18, 2026 10:02 am
by FrankB
I have limited experience, still testing with XT3. But first tests are promising. Trips transferred with TM remain intact even with Sync active. Until you modify them in Tread of course.
Maybe @jfheath can add a comment for the XT2?
Posted: Wed Mar 18, 2026 11:11 am
by proofresistant
Based on everything I’ve tested, TripManager and the Tread app can be used both independently and together.
At least in principle.
However, as has often been discussed, the interaction between the zumo XT2 and the Tread app tends to manipulate routes by shifting shaping points.
Unfortunately, this also happens with routes that have already been transferred flawlessly to the zumo XT2 via TripManager.
Even though there is a suggestion that the shifts are no longer quite as severe as they used to be.
Then there can be synchronization issues with the Tread App, as has also been discussed many times.
It is also relatively irrelevant how the routes were transferred to the navigation device, via SD card, GPX import, the Tread App, or TripManager, how ever.
In short, TripManager does not cause any issues when used in combination with the zumo XT2 and tread app; at least, I have not observed any.
The Tread App behaves as usual—sometimes causing problems, sometimes not, but, as always, this is independent of TripManager.
The takeaway is that TripManager helps identify problems, but it doesn’t cause any, quite the opposite, in fact.
Posted: Wed Mar 18, 2026 12:49 pm
by Oop North John
On a steep learning curve and failing. I have routes in my XT2 which Basecamp shows are in the internal storage, and I've selected "XT2" with Trips / POI and GPX in the drop down but I cannot see the "system" folder that seems to be fundamental to the whole operation. How do I see it please?
Posted: Wed Mar 18, 2026 1:09 pm
by proofresistant
Have you enabled the system folder view?
It's a bit hidden.
It's been mentioned somewhere before, but I can't find it right now - here's a quick guide:
- Tap the current speed there, even if it's 0
- Then touch and hold the speed icon in the next screen - nearly 10 seconds
- This will take you to an advanced menu
- go to Configuration and settings
- Show .System - set to Enable
Posted: Wed Mar 18, 2026 1:31 pm
by Oop North John
proofresistant wrote: Wed Mar 18, 2026 1:09 pm
I missed that when setting it up, can now see them
Thanks.
I like how I can easily delete duplicated trips, it feels much safer than doing it in the XT2!
