Where are tracks and waypoints stored in XT2 internally?
Has liked: 39 times
Been liked: 97 times
Germany
Re: Where are tracks and waypoints stored in XT2 internally?
Post by proofresistant »
@FrankB
I now believed that the XT2 did not store waypoints and tracks locally in files, but in the database.
Regardless of whether the zumo XT2 ever had an Explore connection or not.
Then I came across your question, “Do you want to know for sure?”
I thought, yes, I want to know.
I tested it.
  • I reset the zumo XT2 to factory settings and deleted old data.
  • In BC, I transferred routes, trips, and waypoints to the XT2 (without an SD card).
  • Then was the Temp.GPX in the gpx Folder.
  • I powerd on the device.
  • The WPs were imported automatically right away.
  • All tracks were imported, even though I only selected one track.
  • The routes were imported as I had selected them.
  • I reconnected the XT2 to the PC.
  • In BC, I only saw the WPs and routes, and only those were in the current.gpx.
  • I deleted all gpx files from the device gpx folder.
  • The result was:
    that after starting the device, even without gpx files, all routes, waypoints and tracks were still there.
    They were stored in the explore db and the trips.
@proofresistant Excellent test.
I think that also explains the 'reappearing tracks and routes' viewtopic.php?p=26349&hilit=reappear#p26349
Would be something to check for in TripManager.
This is definitely different from the XT.
Has liked: 39 times
Germany
FrankB wrote: Thu Sep 11, 2025 10:25 pm @proofresistant Excellent test.
Sorry, no!
There was many same Trips (duplicates) for one Route in the Trip Folder.
That was the reasen for reappear in XT2.
