You're welcome. Hope you enjoy TripManager and keep on using it.
Suppose you import a GPX "the normal way", via Basecamp for example that is what Shaping point are called. "Shaping point XT(2)" are typically points when a trip is modified on the XT(2) by the Tread app, or as we recently discovered via the "Shape route" function of the XTproofresistant wrote: Wed Jul 09, 2025 6:29 pm If GPX routes are sent to the XT2 as a trip via "Transfer to device", why do the individual shaping points have the attribute "Shaping point" instead of "Shaping point XT2"
That function does not use map information at all. In stead it compares the Coordinates of the shaping point and the next point of the route. It turns out that with a correctly placed shaping point they are always the same. Regardless of the map used. But the route needs to be calculated by Basecamp, or Mapsource, but that is rarely used nowadays.
TripManager has margin of 0.5 meters. That means any shaping point further away will get relocated.
There are 2 reasons why TripManager does not work that way.proofresistant wrote: Wed Jul 09, 2025 6:29 pm I would like to transfer routes to the Garmin as trips so that the XT2 no longer calculates them, even when importing them. It simply takes too many minutes.
1) Simply. I can't. The trip format has not been decoded enough, there are a lot of unknown fields, it would require in depth knowledge of the maps, AND calculation of routes.
2) Even if we/I could, it would not be desired. Suppose the route/trip would have to be recalculated, the XT(2) would do it with it's own calculation method. And you would get a different route at the first deviation. Better to have to route calculated on import and check the result. (Of course anyone may have a different view)
Frank
