Page 2 of 3
Re: CN EU 2020.30 NTU
Posted: Sun Jan 19, 2020 5:03 pm
They released 2020.30 a little while back. I installed it on both Basecamp and Zumo. And since I was being ultra tidy on that day (not to mention being stupid), I deleted all of my other maps.
What happened was that when any route was transferred from Basecamp to the Zumo, the Zumo would start a very long, tedious process of recalculating. This was not normal behaviour - something that it might do if the map on the Zumo was not the same as the map on Basecamp. But this was taking a good many minutes - and I wasn't even trying to load the map in. (And I know all of the little gotchas in Basecamp that might cause this happen).
I managed to find a backup copy of 2020.20 and after a lot of messing about I got that back onto both systems. All has been well since. I wont be installing 2020.30 any time soon.
Posted: Sun Jan 19, 2020 6:09 pm
by mzeist
jfheath wrote: Sun Jan 19, 2020 5:03 pmWhat happened was that when any route was transferred from Basecamp to the Zumo, the Zumo would start a very long, tedious process of recalculating.
Tested this using CN EU 2020.30 NTU on both Basecamp 4.6.2 (W10pro) and on my 590/5, no problems transferring routes, no long recalculation either.
The Basecamp not routing problem seems to be on a Mac not on Windows (at least that is what is posted on various fora)
Posted: Sun Jan 19, 2020 8:15 pm
mzeist wrote: Sun Jan 19, 2020 6:09 pm
Hmmm. Maybe something else was going on. I'll give it another go at some point - without deleting my present maps this time !
Posted: Sun Jan 19, 2020 8:23 pm
by Stu
I have had no issues with routes with the new maps!
Posted: Sun Jan 19, 2020 8:30 pm
by sussamb
Me neither
Posted: Tue Jan 21, 2020 8:50 am
by Dusty ST
Having problems downloading, I picked the 'install all updates' from Express rather than go to options to also install to PC, so both my Zumos have updated but re-running the update to install to the PC means downloading the update again which I've tried a couple of times and consistently stalls at 14.7%.
I've seen this before, usually fixed by waiting a week and trying again. I wonder if Garmin's servers get maxed out with all the update traffic.
Posted: Thu Jan 23, 2020 7:12 pm
by midlife
I changed to the 2020.3 last week and have the same issue, I have an applemac as well and I only get straight lines and even if I recalculate it makes no difference. I am having to go back to the previous 2020.2 to get the route to work properly.
why cannot Garmin get it right, has anyone solved the problem?
Graham
Posted: Thu Jan 23, 2020 10:41 pm
by sussamb
Well most don't seem to have an issue, so something is wrong perhaps with your device/maps. Have you tried a master reset?
Posted: Thu Jan 23, 2020 11:43 pm
by JD Hog
I think I had this issue once or twice when my maps in Bootcamp didn't match the maps on my GPS.
Posted: Fri Jan 24, 2020 10:21 am
by sussamb
midlife wrote: Thu Jan 23, 2020 7:12 pm
Graham
This seems like a Mac issue with the latest map, there are a couple of similar comments on the Garmin forum. It'll be worth phoning Garmin Product Support to report it.
