Can Basecamp assign Route preference to each segment ?
Has liked: 137 times
Been liked: 127 times
Re: Can Basecamp assign Route preference to each segment ?
Post by smfollen »
The route could be split into 2 routes, one to the ferry, and the other from the ferry.
One route is better than two if it can be made to work of course.
LQQK_OUT
Has liked: 41 times
Post by LQQK_OUT »
Peobody wrote: Sun Oct 12, 2025 1:45 pm This appears to produce the same result as using the Direct route point trick in Basecamp. This forces Basecamp to route between two points that it would not otherwise do but what I have since learned is that a recalculation of the route by the device will likely circumvent the stretch of road that Basecamp was forced to route over. I suspect that the same would occur with an MRA created route. Do you know?
I'm not sure. I'll test it out when I get a chance. The HERE maps within MyRoute-app seem to be dynamically updated with road closure information. I can try to route through a road closure. I'm not familiar with the GPX data format, but according to the MRA link above, skip causes the "waypoint listed as a point where no route calculation on the road is necessary, you will only be pointed in the right direction. You could also say that the route pauses, as it were, while you are travelling between the two waypoints and navigation and route calculation will continue when you arrive at the next point."
Seems fairly simple and basic.
Zumo XT2, Zumo 595LM
2011 Harley-Davidson FLHTCU
1993 Harley-Davidson FLSTF
LQQK_OUT wrote: Mon Oct 20, 2025 8:22 pm ...but according to the MRA link above, skip causes the "waypoint listed as a point where no route calculation on the road is necessary, you will only be pointed in the right direction. You could also say that the route pauses, as it were, while you are travelling between the two waypoints and navigation and route calculation will continue when you arrive at the next point."
I believe that is exactly what the "Direct" trick in Basecamp does. It is not routing you over roads to the next route point, it is just pointing you in a straight line to it. Obviously that is what must happen for a route to traverse a ferry crossing.
