That is worth a shot. It may well work.Warrington White wrote: Thu Apr 10, 2025 8:11 am Thanks folks.
I tried again last night with other configurations - its becoming an obsession.
Paring as a GPS to Cardo works OK but no phone..... but its given me an idea
Ill try this when I get home tonight and really screw everything up
Phone to Zumo
Zumo to Cardo as GPS
Phone to bike for music and phone
Cardo to Bike
Helmet to Helmet comms
This will mean that the Nav will come through on the Cardo channel 2 with the bike (phone and music) using channel 1
Zumo as hub with phone paired to Zumo and headset paired to ZUmo has been 100% reliable for me. Connects within 30 seconds of turning everything on. Usually much faster. And it never misses a beat. Tread is installed but is not allowed to synch.Warrington White wrote: Thu Apr 10, 2025 8:11 am The one that annoyed me the most was having the Zumo as the hub and the music being choppy when using intercom.
The advantage of having the bike in the equation is that I can use my handlebar controls AND the zumo for the controls. Very useful for volume controlled by the bike and also when you get a shit tune and want a quick next.![]()
Only when I introduce music from the phone, or the XT2 / Tread synchronisation do I have any problems.
If you have your XT2 set up to synch with the Tread App, it is worth getting rid of it. It means an XT2 restore to factory / reset, and delete Tread from phone. Later you can set up Tread again - without allowing it to store data / synchronise.
Never mind about whether you want to use Tread synch or not. You will be able to find out what is causing the issue - the phone music or the Tread app. Once you know that, you can start working out how to get the best of what works. The chances are that not everything will work.
I mean - you can pass the phone operations to the XT2 (make call, answer call, access phone book, view call list, see who is calling etc etc. But I do not think it will allow you to pass that 'acquired' control on to another device.
Using different channels may be a solution. I have tried, without success. But I didn't try particularly hard to make it work. (Ie I tried once and gave up 'cos it wasn't what I wanted anyway !!)
