Mikey wrote: Sun Mar 09, 2025 9:38 pm
What I should have written is that the XT was not keeping me informed of upcoming points along my Route, and this is because I had placed only route Shaping Points (non-alerting Waypoint) If I had Via Points (alerting Waypoints), I would see them coming up (time/distance) on the XT, I assume. I like would that.
Are there any flaws in my thinking above?
If you want the upcoming points to be displayed - (say distance to, time to etc in the trip data that you can display on the right of the landscape screen - it will show only the data to the next Via Point. (Alerting Route points).
To get this - you don't have to be using Waypoints. Any route point that is set as a Via Point can be shown.
The image shows Time of arrival at the next Via (orange flag)
Distance to the next Via
Distance to the end of the route.
ETA for the end of the route.
All four of those 'buttons' can be changed to show what you want from quite a large list.
(The yellow '1' is becasue I pinched the image from one of my other pages on this website.
Now for the question that you didn't ask.
There is one other flaw - which will be the reason why you will probably not understand my answer above.
I think you are misunderstanding the term 'Waypoint'.
We are talking Garmin - so we try to use Garmin's terminology.
Route point is the term used to refer to any point on a route. It is coded as
<rtept ....> in the gpx files.
Each route point is subsequently defined either as a
ShapingPoint or as a
ViaPoint
A Waypoint is a point that you create separately from the route. You create it and save it. You can store with it additional information. Typically a detailed address, post code and phone number. Which is very handy, 'cos if you have such a point in your Zumo, you can show it on the screen and ask the Zumo to call the number. Subsequently you can add a Waypoint to your route. The same name is copied and the same lat/long coordinates are copied to the route. It defaults to being set as a Via Point, but like all other route points, it can be set as either a shaping point or as a Via point.
So a Via Point is not the same as a Waypoint. A waypoint is not the same as a Via Point.
Neither is a Shaping point the same as a Waypoint (and vice versa).
As far as a route is concerned, all we are interested in is whether a route point is a shaping point or a via point.
But only points that were created and saved as Waypoints in Basecamp are put into the area accessed by Favourites (UK) / Saved (USA) / Waypoints (XT2)
You can build a route quite happily with no Waypoints in it at all. Lots of route points, but no Waypoints.
The issue is compounded because many people do not like Basecamp. And they pick up the language used by programs like MyRouteApp.
They use the term 'waypoint' to mean any point on a route. They too use the terms Via and Shaping points. But they are also consistent in pointing out that any of their waypoints (route point) can be set as a Via or as a Shaping. So I have not seen anywere that states a Via Point is the same as a Waypoint. A waypoint can be used in a route and set as a Via Point. But it can also be used in route and set as a shaping point.
The problem when answering questions is when people say that they have a route with a Waypoint in it - what do they mean
Do they mean they have a route point set as a Via point (which is common)
Do they mean they ahve a route point set as a Shaping point (seen recently of FB)
Do they mean that they have created a route point with the flag tool (which is the correct interpretation if we are talking BC)
Do they mean they have created a waypoint in Explore or in Tread (possible, but not relevant in this case).
Why does this matter ?
Well - Genuine Waypoints (Garmin definition) behave very differently in a route situation.
They keep the name that they were given
They do not move
They are stored in the Favourites / Saved area
They are stripped out of the GPX file if they are placed in internal storage.
They are not available to import if they are on the SD card (unless you have at least on waypoint in internal storage).
If they are in internal storage and are deleted, they can not be re-imported.
And if used in an XT2 and it is set as a Via Point (say), and the Via Point is moved by the XT2 or by the Tread App - they become two points - the Via point in a new loaction on a slightly moved route. And a Waypoint which has satyed in position, but which the route no longer visits. Oh yes. Sorry sir, did you want to go to your hotel on that quiet little back road ? Sorry, we've moved the route onto a motorway. You'll have to find your own way.
I exaggerate. But not much.
And most commonly - many people think that a waypoint is the same thing as a via point. Which it isn't. In my well planned long tours I use waypoints a lot - purely so that they keep their name and location - but most of them are set as shaping points.
Does it really matter ?
No not really. Call things what you like.
