I have to try that next update,...
Just to see if it works or not...
RJ
Update to XT taking forever
Chopperbob
- Has liked: 21 times
- Been liked: 4 times
Re: Update to XT taking forever
Bluetooth can interfere and slow some WiFi speeds to almost zero on some devices. I had this issue on a phone once, if I wanted to connect to my home router I needed to toggle BT off. My tablet worked fine with BT on.cr0100 wrote: Thu Jan 23, 2025 8:21 pmMy XT is weird when it comes to downloading updates via WiFi. I can't explain it, but if I have Bluetooth enabled, the download never seems to happen. If I toggle Bluetooth OFF, then updates download and install in a fairly reasonable amount of time.Chopperbob wrote: Sat Jan 18, 2025 3:58 pm Started this morning at abt 1100 an update, it is now 1700 hrs and there are still 12hrs to go….
Connected via wifi, but is this normal???
I have no idea why it behaves that way, but that's been my experience.
I keep forgetting that WiFi and BT are both in the 2.4GHz spectrum. I remember now I used to have problems with a bluetooth headset on my laptop when the only wireless I could connect to was 2.4GHz. Thanks for the reminder, it's a bit less aggravating knowing this!
