Page 2 of 2
Re: Deleting old maps.
Posted: Thu Dec 19, 2024 10:07 am
In Basecamp: Maps / Manage Map Products
This dialog box tells you exactly where each map is stored.
When the Zumo is connected, the library pane on the left shows which maps are installed on the Zumo. Click on any map, and the bottom pane will reveal the name of the img file for the selected map. These files may be in .system/Map.
Additional files that are associated with the .img file have the same name but different extensions.
eg D6159300A.img, D6159300A.gma, D6159300A.unl
Posted: Thu Dec 19, 2024 11:23 pm
by wks
Thanks John. On my Map Product Manager screen i have the latest NT map and the latest NTU map. I also have a NT map from 2008 which i either bought or it came with my 550. Is that one ok to delete ?
TIA
Posted: Fri Dec 20, 2024 6:52 am
by sussamb
Yes, unless you wish to keep it
Posted: Sat Dec 21, 2024 2:39 pm
by colirv
On my PC I remove old maps using the Windows Uninstall feature. Saves messing about with folders.
Posted: Sat Dec 21, 2024 3:22 pm
by wks
Many thanks to everybody.
Posted: Sat Dec 21, 2024 7:56 pm
by sussamb
colirv wrote: Sat Dec 21, 2024 2:39 pm On my PC I remove old maps using the Windows Uninstall feature. Saves messing about with folders.
Unfortunately that doesn't delete the install files that Express leaves behind.
Posted: Sun Dec 22, 2024 11:08 am
by colirv
sussamb wrote: Sat Dec 21, 2024 7:56 pm
Ah! They're hidden away in the RMU folder. Thanks for that.
