Re: what3words & Garmin Drive App
Posted: Fri Feb 23, 2024 1:30 am
does anyone know if delm8 still works with garmin drive?
Dedicated forums for Garmin Zumo motorcycle satellite navigation. All questions answered from problems, route planning, touring to tips and tricks
https://www.zumouserforums.co.uk/
I guess not. Your question implies that it worked once, but doesn't work now.
delm8 is a property housefinder from post code, you type in the postcode then, delm8 lists all the properties in that postcode, house names and numbers, once selected you can send the co ordinates to google maps or gamin drive app to send to sat nav. i stopped using delm8 as its a paid service, and what 3 words could almost do the same thing for free.jfheath wrote: Fri Feb 23, 2024 6:52 amI guess not. Your question implies that it worked once, but doesn't work now.
No one has ever mentioned Delm8 before. A route planning app for delivery drivers, according to Google.
So possibly not used by many Zumo users.
If you provide a bit more information, someone may be able to help. I guess that Delm8 uses a mobile phone for navigation.
This forum is aimed at Zumo users.
Garmin Drive is a phone app designed specifically to work with the Zumo XT.
(I am using Android on Samsung)simoncrewe wrote: Thu Nov 23, 2023 9:11 am Many thanks Stu, I assume when Garmin updated the Drive App recently they changed something, intentionally or by accident!
Zumo is the name of the range of sat navs for motorcyclesSelsley wrote: Mon Feb 26, 2024 9:15 pm update, reinstalled delm8 today and it sends coordinates to garmin drive then to my sat nav no problem,the one thing i noticed is that the coordinates seem to be a lot longer than they used to be... and since i updated my voice controlled garmin the other day trying to get what 3 words to work, it now doesnt want to work as well, i get its attention and say search postcode, then it refuses to do anything, im starting to wonder if garmin is as good as they are given credit for. i know i likely came here by accident but the topic was about what3words and garmin drive, no idea what zumo was, i thought it was the name of the forum or forum website, but zumo or satnav, the problem is with garmin drive.and thus is relevent to both.
Note the campsite name label in parentheses.geo:0,0?q=53.33704,-1.92364(Chinley Campsite)
Putting aside the slight difference in the coordinates, the main difference is that what3words does not send a label in parentheses.geo:0,0?q=53.337039,-1.923649
Excellent info. I'm not an Android developer, but I can relate to the info.
I built the test app by hacking the "hello world" example in the B4A rapid development tool. I'll do an explanatory post on the forum of B4A and link back here, as it might help others looking for a way to spy on intents!FrankB wrote: Fri Mar 01, 2024 1:54 pm I would be interested in your source code, just out of curiousity. Send me a PM if you agree.
As I mentioned in my post above, it looks like sending what3words to Google Maps and then on to Garmin Drive is a viable workaround, albeit one that might need online access to the Google geocoding api. I'll have a look at what the intent is from Google to Garmin.FrankB wrote: Fri Mar 01, 2024 1:54 pm I cant prove it, because I did not keep the evidence. But it is my strong belief that, about a year ago, it was possible to share a location from Google maps to Garmin Drive. All of a sudden it stopped working. When I tried it a week or 2 ago it worked again. Can you verify that with your app?
