Page 2 of 6
Re: Easy solution to install City Navigator maps on PC/Mac
Posted: Fri May 28, 2021 3:16 pm
by ray6576
I upgraded my Garmin express and had no problem updating my maps for Basecamp. I check the map information and Basecamp reports it as unlocked at least the Mac version in the US seems to be doing what it should.
Posted: Fri May 28, 2021 4:06 pm
by sussamb
Temporary solution for this - from the folder .System/Maps on the Zumo XT copy the file 'D6210130A.gma' to 'c:\Users\(username)\AppData\Roaming\Garmin\Maps\ this should unlock the map in BaseCamp...
Alternatively you could copy the .gma to 'c:\ProgramData\Garmin\Maps\', this also should work....
Posted: Mon May 31, 2021 8:33 am
by Triplog
Just done on mine, map already unlocked on installation. Thanks for this ingenious solution!
Posted: Thu Jun 03, 2021 8:05 pm
by Peobody
I don't have a D6210130A.gma file in .System/Maps on my Zumo XT. There are 7 other .gma files though. Is this file map specific? If so, a way to identify the file to unlock City Navigator North America NT 2022.1 and its Foursquare and Parkopedia counterparts would be appreciated.
Posted: Fri Jun 11, 2021 10:42 am
by Andrew_XT
Today i have updated the Zumo with 2022.1 map.
After with Garmin express i have install the map on the PC but still the problem "Map Blocked"
I have try coping the file .GMA inthe PC folder, but doesn't work
More solution?
Work with the map on Zumo is very very slow
Posted: Fri Jun 11, 2021 11:39 am
by simoncrewe
Contact Garmin support, like I have & insist they sort the problem out. We should not be doing their job for them.
Posted: Sat Jun 12, 2021 5:58 am
by sussamb
Did you update Express first? The latest version is meant to have resolved this?
Posted: Sat Jun 12, 2021 9:29 am
by Rofor
Peobody wrote: Thu Jun 03, 2021 8:05 pm
Yes, they are map-specific - try to identify it by the date of the file, this should be the safest variant! I didn't know, if the same counts for the us version 2022.10 of CN, but for the european CN it is D6210180A.gma...
Posted: Sat Jun 12, 2021 9:34 am
by Rofor
sussamb wrote: Sat Jun 12, 2021 5:58 am
You're sure? As far as i know, Garmin Express 7.6.0.0. has caused all this troubles (not unlocking maps, devices not found and so on)!?
My solution for the problems was to uninstall GE 7.6.0.0. (do NOT tick 'delete all files belonging to Garmin Express'!!), install 'old' Garmin Express 7.5.0.0., install CN 2022.10 for BaseCamp with 'fake-Zumo-XT' and install CN 2022.10 on the unit with real Zumo XT - no problems at all!
Posted: Sat Jun 12, 2021 9:40 am
by simoncrewe
Garmin have deleted GE 7.6 & reverted to 7.5 as the new software did not work & was loading locked maps to Basecamp.
I currently have a case open with Garmin support to hopefully get this resolved.
It does however, seem to be unique to the Zumo XT.
