Page 2 of 3
Re: Incident detected
Posted: Tue Aug 14, 2018 8:37 pm
by Stu
I found that on the Garmin website
Bit of poor performance for Garmin with regards to not getting back to you! when I contacted them I always got a reply within a couple of days even if it was as if they where reading off a script
Posted: Tue Aug 14, 2018 9:00 pm
by tojjer
I'm phoning them tomorrow ( that's if they're not too busy training staff again to answer! )
It actually says now that incident detection is disabled, it didn't say anything before. I'll give it a go tomorrow and report back
Cheers Stu
Posted: Wed Aug 15, 2018 4:01 pm
by tojjer
Right, went out in the car this morning, and used the sat nav to direct me to town. Never detected an incident once. Brilliant, I thought.
Obviously I needed to set up an emergency contact, and then delete it to stop those annoying messages.
Went out on the bike just now, and I hadn't gone 50 yards before it was telling me it had detected an incident. GRRRRRRRRRRRR!!!!!
I can only think that the sensors on the unit are way too sensitive and are picking up every bump in the road.
I phoned Garmin and actually got an answer today, albeit after 12 minutes of waiting.
The very pleasant lady went through things I had already done such as setting up an emergency contact, then deleting it, a soft reset by holding the power button for 12 seconds, and using the restore function.
Tried all that but nothing changed, so did a full factory reset by where you hold down the screen in the bottom right hand corner whilst powering up the unit. This erases all data and puts it back to day 1.
Just about to go try it again now.................
Posted: Thu Aug 16, 2018 9:34 am
by tojjer
Ok, so I did a full master factory reset. Went out on the bike and it didn't do it once. I tapped it on the desk gently and it came up with that message, so I can only assume its working correctly now.
It seems that the last software update might have been corrupted somehow. I've done an update since resetting it and it seems fine now.
Posted: Thu Aug 16, 2018 11:58 am
by Fitz
Good result, how much of a drag was it to set things up again after the full reset?
Posted: Thu Aug 16, 2018 3:55 pm
by tojjer
Fitz wrote: Thu Aug 16, 2018 11:58 am
I think all I had to do was connect to Wifi, put in my email address and my choices for routing. 5 mins if that
Used it again today, perfect
Posted: Fri Aug 31, 2018 12:57 am
by zenwave
Hi everyone, first post on this board, coming from across the pond (New York).
Just got the 396 LMT-S a couple of weeks ago, and really love it... with the exception of this "Incident Detected" nonsense that plagues every ride!
I called Garmin support here in the US, and they confirmed that it currently
can not be disabled! I informed the fellow that constant (on mine it never stops detecting 'incidents') pop-ups on the device could be a dangerous distraction to the rider. He agreed and put in two separate engineering requests: 1. To make it so that incident detection can be disabled, and 2. To adjust the sensitivity of incident detection.
May I suggest that any of you who have not yet contacted Garmin about this, do so post-haste, as the more complaints/requests for change they get, the sooner they may get this into a software update... their UK number is 0808 238 0000 (found here:
https://support.garmin.com/en-GB/?productID=610131 ).
On a personal note, I'm in my mid-fifties, currently ride a Victory Vegas 8Ball, just finished a fun summer ride here in the states, which included a flight to London for a two week stay (never saw more scooters in my life).
Looking forward to learning more about the Zumo from the shared knowledge here... Cheers!
Posted: Fri Aug 31, 2018 12:27 pm
by tojjer
As mentioned above, I was getting this every 100 yards or so. I contacted Garmin UK and they advised doing a full factory reset, and it hasn't done it since.
I didn't realise, but in the very bottom right hand corner of the screen, if you press and hold there whilst turning the unit on, it asks if you wish to do the full factory reset. Did that and cured it. It will wipe everything obviously.
Garmin UK reckoned it was possibly down to the last update not installing properly. Worth a go buddy, it don't take long and it's updated fine ever since with no going back to those poxy incident messages.
Posted: Mon Sep 03, 2018 11:23 pm
by zenwave
So I tried the factory reset, and it worked.... for a few miles.
Did a 400 mile overnight trip in the Catskill Mountains of NY this weekend, and after about 60 miles, it was back to non-stop annoying pop-ups.
Sure hope they fix this with a software update soon.
Posted: Fri Sep 14, 2018 9:40 pm
by RiderJenny
Hi guys, Jenny here from Rider Magazine in the U.S. I've got a 396 LMT-S that I'm reviewing for the magazine and it has started doing this Incident Detected thing as well. I headed out on a 5,000-mile endurance ride...day 1 it was fine, day 2 it was fine...day 3, it suddenly started throwing up those alerts.
Just wanted you to know that I've reached out to Garmin with my rather large stick. Hopefully they address it sooner rather than later. Seems a simple software update might solve it....
