Swith from Mac To PC
burtsr
Post by burtsr »
I've just changed from a Mac to PC version of Basecamp. Can someone tell me how to click on a route and drag it so I can change where it's going? I'm sure it's easy but I can't seem to figure it out.
thanks
yorky
Been liked: 16 times
Re: Swith from Mac To PC
Post by yorky »
Open the route in Basecamp and in "Tools" you will find the option to "insert, move, erase point, and divide route.
Click on the route so it's highlighted then Alt + Left click where you want to 'rubber band' the route. You can then drag and click. I suggest you work through this tutorial for more information on how it all works:
Many folks use the "rubber band" drag and drop but I am a tools guy. I use the INSERT, MOVE and ERASE tools from the toolbar to modify my route. If you don't see them:
- place your cursor directly above and outside the map;
- right click;
- tick EDIT FEATURES.
They will show up now. Using drag and drop with the dotted vertical line directly to the left of a features box, you can re-order where things are. Play with it, you'll see. Other features can be added/deleted and moved around this way. I uncluttered mine long ago.
colirv
Has liked: 66 times
Been liked: 64 times
Post by colirv »
I have the "Insert" button on the toolbar along the top. Highlight route, click on "Insert" button and drag the route to where you want to insert a point. I use the + and - keys on the keyboard to zoom in and out. If doing several inserts it sometimes wants to insert from the wrong point. Clicking "undo" puts this right. It'll probably take a bit of trial and error to master it, but it can be done!
Colin
BMW R1250RS
https://www.namrider.com
burtsr
Post by burtsr »
sussamb wrote: Wed Dec 16, 2020 4:09 pm Click on the route so it's highlighted then Alt + Left click where you want to 'rubber band' the route. You can then drag and click. I suggest you work through this tutorial for more information on how it all works:
This is just what I was looking for. Thanks
