Turn off audio alert for Via-Points?
Rip
Has liked: 4 times
Post by Rip »
Is it possible to turn off audio alerts for Via-Points either in the Zumo 595 device or in Basecamp? I need to have Via-Points in my GPX files for navigation purposes (such as as getting a bit off track by accident and being able to navigate back on track) but having the constant audio alerts every few miles mutes my intercom conversations while the alert is being read out which is really annoying.
Has liked: 311 times
Been liked: 356 times
Re: Turn off audio alert for Via-Points?
Converting them to shaping points will stop them alerting, but is there a reason why you don't want that?
Rip
Has liked: 4 times
Post by Rip »
There is a reason yes, when you go off route by accident the satnav is much happier finding its way back because it navigates to the nearest via point, it will just ignore shaping points.
Breezly
Has liked: 22 times
Been liked: 32 times
Post by Breezly »
Yes many folks experience this behaviour as a limitation. There are a couple of ways of dealing with it.
Personally, for the most part, I don't have the GPS route me back to the route. I typically have relatively few viapoints in my routes. I set Recalculate to off, will zoom out and manually route myself back to the original route. In rare instances I'll add a new viapoint to the route on the GPS at the location where I want to rejoin the original route. Another option is to change one of the routes already existing shaping points to a viapoint on the GPS itself.
With experience using the 590/595 routing I think many folks develop a good strategy of the right number and mixture of viapoints and shaping points that works best for them with their particular routing and touring practices.
Breezly
Has liked: 22 times
Post by Breezly »
Rip
Has liked: 4 times
Post by Rip »
Breezly wrote: Tue Jul 28, 2020 6:07 pm Yes many folks experience this behaviour as a limitation. There are a couple of ways of dealing with it.
That makes sense thank you.
Rip
Has liked: 4 times
Post by Rip »
I'll do my next route with no via-points and recalculation off and see how I get on.
