Double click the route in the lower left hand pane or right click it and select OpenSleurth wrote: ↑Thu Jul 16, 2020 6:40 pm I've clicked everything but there's no options to bring up properties. I can open the route and various boxes, but nowhere can I find something saying about 'alert on arrival.'
What I can do is delete all the waypoints on the route, and the highlighted route is still showing on the map. Will that work, will the satnav still guide me around the route?
Editing GPX files in basecamp - adding shaping points
Re: Editing GPX files in basecamp - adding shaping points
- Has liked: 96 times
- Been liked: 201 times
Bingo! You hit my nail squarely on the head! I "upgraded" from a Garmin nuvi and have been extremely frustrated at the lack of intuitiveness of the 595. My nuvi was significantly better at anticipation but then again, it was a much less complicated unit. The thread I linked earlier is much of what I've had to learn & in some cases re-learn. And mostly I had to convince myself that this is just how it is.Sleurth wrote: ↑Thu Jul 16, 2020 7:03 pm I looked back at the route I did at the weekend, where I missed a turn and had the routing issue - and it has no waypoints! When I open it up, it shows beginning and end, just 2 viapoints. So how did it happen?
I appreciate it may be me doing something wrong, but even so, this system isn't very intuitive. For £400, I expect better.
The problem was that the gpx had no waypoints (via points/shaping points) so the option didn't come up. So I don't know how I can correct the routing issue when there are no waypoints.sussamb wrote: ↑Thu Jul 16, 2020 9:05 pmDouble click the route in the lower left hand pane or right click it and select OpenSleurth wrote: ↑Thu Jul 16, 2020 6:40 pm I've clicked everything but there's no options to bring up properties. I can open the route and various boxes, but nowhere can I find something saying about 'alert on arrival.'
I've tried creating my own route in basecamp and now can see what you mean about them
