595 FW downgrade
bolek
Czech Republic
595 FW downgrade
Post by bolek »
Hi, is any way to downgrade Zumo 595 from FW 4.60 to 4.40?
In 4.60 is a bug with selecting "Favorite POI" from map. ( see )
Garmin-support says :
"After further investigation, it appears we had a case open regarding this issue. Sadly this issue will not be corrected at this time" :evil: :evil: :evil:
I tried the procedure for change 590 to 595, but I was not successful... :(
Has liked: 329 times
Been liked: 360 times
Re: 595 FW downgrade
Do you have a copy of your previous gupdate.gcd? If not Google Garmin Perry, you can get previous software updates there.
bolek
Czech Republic
Post by bolek »
unfortunately, when I save GCD file (I tried FW 4.40 and 4.30 from Perry) on SD card, then after restart Zumo asks : The software on the device is newer than the one you are installing - do you want to continue? I set YES, installation is in progress, but after restart it asks exactly the same. When I finally give NO, after Garmin starts up, it reports that the 4.60 update has been installed ...
I used this method on Garmin Oregon, but it doesn't work for Zumo... Am I doing something wrong?
Not sure but I'd try it on the device rather than the card
bolek
Czech Republic
Post by bolek »
when I tried it on the device, nothing happened - Zumo did not report an update. It only found it on an SD card...
On the device it needs to go in the .system folder, that's normally a hidden folder.
bolek
Czech Republic
Post by bolek »
Oh, thanks! I'll try it when I get home after the weekend.
Vespamarc
Been liked: 14 times
Belgium
Post by Vespamarc »
I have 4.60 also and don't have problems with my favorite POI, everything works perfect here.
mzeist
Has liked: 33 times
Been liked: 31 times
Post by mzeist »
your favorite POI screen icons seems very small, may be a factory reset will sort things out?
I run 4.60 without problems.
Groet, Marcel.
bolek
Czech Republic
Post by bolek »
[mention]sussamb[/mention] : Big thanks! With .system folder downgrade works, and now, I can use my favorites without restrictions ! 8-)
[mention]Vespamarc[/mention] and [mention]mzeist[/mention] : Factory reset did not help... This bug is confirmed from US Garmin, maybe it only involves some revisions...
