Download POIs from Zumo
Fallguy67
Has liked: 43 times
Post by Fallguy67 »
On a previous forum (no defunct) there was a "How to" on downloading POIs (Favorites) from the Zumo. I am needing to do this and can't remember how. I need to get them as a CSV or if that's not possible a way to convert them to a CSV once downloaded.
I have new vehicle with built in navigation and want to transfer the POIs from the Zumo to it.
Any help is greatly appreciated!
Has liked: 312 times
Been liked: 358 times
Re: Download POIs from Zumo
Please clarify whether you're talking about POIs or favourites, as they aren't the same. The simple one is your favourites are contained within the current.gpx file in the GPX folder of your device. You can then import that into BaseCamp and export it as a csv file. Google Search for other ways to convert them.
Fallguy67
Has liked: 43 times
Post by Fallguy67 »
It is my Favorites, guess I said POI because that is what they will be in new vehicle.
I think I figured out basically doing what you said. Just going to have to cleanup the CSV file before upload to truck.
